550's going to be enough
Old Apr 1, 2003 | 06:06 PM
B16 BROTHER's Avatar
Default 550's going to be enough
I have a b16 with a max rev manifold,garett t3/t4, tial 35 mm, greddy type s bov,and skunk 2 manifold. I blew my motor and I am now building it with darton closed deck sleeves stock bore crower rods je pistons 10-1 compression (which i think is a little high but my mechanic says otherwise) skunk 2 valves, valvesprings and retainers and skunk 2 cam gears. My question is are the 550 rc's going to be big enough for me to get tuned out on 14 to 16 psi. P.S. I have a areoquip inline pump, and the car is not daily driven.
Old Apr 1, 2003 | 06:16 PM
Acura_I-RS's Avatar
Default Re: 550's going to be enough (B16 BROTHER)
i think they will be alright, i wouldnt run much more boost than that though
oh, and i would ditch the inline pump for a walbro 255lph!!! my $.02
oh, and why such high compression??
[Modified by Acura_I-RS, 3:16 AM 4/2/2003]
Old Apr 1, 2003 | 06:25 PM
Default Re: 550's going to be enough (Acura_I-RS)
I think my fuel pump is pretty good came off of a turbo mustang, but I am welcome to opinions and will look into it. On the compression I have never heard of it but my mechanic has never told me anything wrong, and he has had a turbo motor with same compression and made excellent power. And on the boost I think I will be able to handle because of my sleeves. But I know traction is going to be a prob but I am building my car for roling starts i like the high end. Thank you for all of ur input your help was greatly appreaciated.
Old Apr 1, 2003 | 07:22 PM
ghettocrxsi's Avatar
The higher the compression the less boost you will need to make the same hp.. ex.
9:1 with 15 psi is like 10:1 at 8-9 psi...
Just make sure its tuned really good.. that pump should be alright.. people just like running intake pumps.
I was going to run 10:1 comp on my sohc with like 10 psi but I got 8:5.1 instead cuz I got a good deal on them..
Have fun with boost.. I pick up my block this week cant wait.. sohc
Old Apr 1, 2003 | 08:10 PM
Stag 2000's Avatar
Default Re: 550's going to be enough (ghettocrxsi)
Its not that much of a differance.
Old Apr 1, 2003 | 09:31 PM
Default Re: 550's going to be enough (Stag 2000)
I was just showing that it takes less boost to make the same hp on a higher compression motor
jdmb16ef8
57
Jun 6, 2014 10:52 AM
93delslow315
Nov 30, 2010 03:33 PM
94-integra-ls
May 29, 2008 11:28 AM
nah22accord
Feb 2, 2006 07:57 PM
jdmcivic1999
Aug 19, 2005 06:35 PM
