turbo compression ratio question
Old May 27, 2008 | 09:32 PM
94-integra-ls's Avatar
Default turbo compression ratio question
ok i know the golden rule low compression for turbo set up yada yada yada i was going to run 8.8 or 9.0 to 1 but i came across a good deal on a set that are 10 to 1 and from what i have been reading with a little extra tuning and less boost the ratio would be ok and if i got a thicker headgasket that would also lower the compression ratio a little as well so my question really is would it be ok to run 10 to 1 compression ratio pistons in a turbo b18b1 on 9lbs tuned with crome mods supporting are i beam rods eagle crank itr water pump and oil pump port and polish head skunk to retainers and springs skunk2 cam gears catch can 450cc dsm blue tops help please guys
Old May 28, 2008 | 10:03 AM
Default Re: turbo compression ratio question (94-integra-ls)
bump
Old May 28, 2008 | 04:11 PM
Schister66's Avatar
Man U FTW
If you have an FI question, post in the FI Forum...to make this easier, i'll move it for ya champ
Old May 29, 2008 | 10:59 AM
Default Re: (Schister66)
thanks man i ended up just biting the bullet and buying some cp 9:1 compression pistons to be safe
Old May 29, 2008 | 11:28 AM
SpoolnG2's Avatar
Default Re: (94-integra-ls)
9:1 is a good choice
Rooftop voter
Nov 2, 2008 10:01 AM
jdmcivic1999
Aug 19, 2005 06:35 PM
LSEGHATCH
Oct 6, 2004 07:44 PM
transmission11
Dec 30, 2002 10:02 PM
MUGENTYPER
Feb 6, 2002 06:31 AM
