520whp B Series 6266 on Pump Gas
LS/Vtec on stock sleeves
-JE/Eagle combo 9:1 comp 81.5mm bore
-Stock cast head, Supertech Valvetrain
-Skunk Pro1's dialed in on the dyno
-LoveFab Ramhorn
-T3 6266 .82 backside
-2.5 piping into i/c , 3 inch upper cold pipe
-Victor X mani with 70mm cast TB
-255 LPH intank and 1600 old school low impedance injectors
-S300 on C.P.R
-93 Octane
18psi with the run stopped at 9100rpm.
RPM will be turned up at the track after a couple of shakedown passes. There's about another 10-20whp in the next 500 RPM....the plugs told me that i was at the edge of what 93 had to give.
-LoveFab Ramhorn
-S300 on C.P.R
-93 Octane
Who is Mr Robot?
Re: 520whp B Series 6266 on Pump Gas
No meth injection or anything like that?
Those are some of the highest numbers I've heard of on straight pump 93. Makes me wonder what the car would make on e85 or oxygenated and leaded race fuel
Amazing numbers. Surprised you don't see everyone with a 500 HP honda. It's all in the tune. And I guess most people over build the motor for what they actually push it to.
Great numbers. Really really impressed. Almost as impressed as I was when I saw the RWD 500 HP Crx. Which is saying a lot!
No meth or anything of that sort. The original plan was for e85, it might be out of the budget this year so i'm thinking some 110 will let us rev out a little more and bring in a few more pounds of boost.
Rev'ing it out higher isnt going to push the 93 octane barrier any worse. Your peak torque is where that lies.
Great powerband none the less. Reminds me of back in the day of 2004-2005 when 'they' said you could never reach 500 on pump on a b series. I think 4-5 cars I did around that year reached 500 on pump and not one failure.
Enjoy it.
Enjoy it.
-LoveFab Ramhorn
-S300 on C.P.R
-93 Octane
-LoveFab Ramhorn
-S300 on C.P.R
-93 Octane
Where'd the pro1's end up at?
Muckman! Thanks, race season for both Grand-Am and World Challenge series is coming to an end, so I finally have some down time. Havent posted here in forever.
to the OP: if its running a true 10.8:1 (if the wideband is accurate) lean it out to 11.8:1-11.9:1 flat, it will probably smooth out the powerband even more. no need to run that rich, it will pick up more power.
Im sure that there are plenty of 500hp pump 93 cars out there. Not everyone post online. I have over 500 pump 93 but im a nobody on honda-tech, so why even post about it? lol
Who is Mr Robot?
I'm well aware of this, my last built motor, a 2.1 liter ls/vtec wth custom everything from crank, to cylinder head, to cams, and intake manifold etc made almost 550whp on 93, no helpers
the trick is building a car that will reliably keep making that 500+whp on 93 and not **** the bed
BearsEK-KMSU
208
04-22-2014 05:27 PM
