500cc Injector Question
Old Jan 15, 2007 | 05:42 PM
sundownz's Avatar
Default 500cc Injector Question
I can't find a clear answer to this... perhaps I'm just using the wrong search terms so if it has been covered numerous times a link would be cool with me too. I am still somewhat of a boost n00b so there are some things I just don't know.
The question is this... I ordered some 500cc injectors for my D15B7 w/ Greddy Turbo Kit controlled by the Greddy E-Manage system. I have had the car tuned already with the stock injectors, they go static around 5k RPM so I've kept it under there since the tune. When I get the new injectors will they be controlled just like the stock injectors were by the E-Manage system? If I go ahead and install them now should I be okay to drive it around right away before a re-tune? In other words... will the E-Manage keep these higher flower injectors from just drowning my engine in gas even though it was tuned for stock injectors?
Thanks in advance!
Old Jan 15, 2007 | 05:59 PM
numbnuts22715's Avatar
Default Re: 500cc Injector Question (sundownz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sundownz &raquo;</TD></TR><TR><TD CLASS="quote">I can't find a clear answer to this... perhaps I'm just using the wrong search terms so if it has been covered numerous times a link would be cool with me too. I am still somewhat of a boost n00b so there are some things I just don't know.
Thanks in advance!</TD></TR></TABLE>
Im not entirely sure... But I think you will need to get it retuned right away. I dont think the idling will be right if you just swap them out now. Take it to a tuner and swap them when youre there
Old Jan 16, 2007 | 02:45 AM
sundownz's Avatar
Default Re: 500cc Injector Question (numbnuts22715)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numbnuts22715 &raquo;</TD></TR><TR><TD CLASS="quote">Im not entirely sure... But I think you will need to get it retuned right away. I dont think the idling will be right if you just swap them out now. Take it to a tuner and swap them when youre there </TD></TR></TABLE>
If I cannot get a definitive, "Yes, you'll be okay" that is what I'm going to do I was curious so I could save some time once I got to the tuner (the one I go to is an hour away), and for the sake of knowing this information as well.
Old Jan 16, 2007 | 04:11 AM
nasteboyii's Avatar
Take car to place to tune, then put in new injectors, it needs to be retuned if new injectors are installed
hope this helps
dan
Old Jan 17, 2007 | 02:59 AM
sundownz's Avatar
Thanks guys. I'll just take the injectors to the tuner with me when I go back next time and put em' in there.
Old Jan 17, 2007 | 05:26 AM
nasteboyii's Avatar
Default Re: (sundownz)
NP, Good luck
dan
mingbling96
Jul 3, 2006 10:43 AM
Integra21
Apr 25, 2005 07:34 AM
mike93eh
Mar 17, 2005 05:16 PM
E46M3CB
Nov 8, 2003 02:39 PM
slwazgsr
Sep 4, 2002 11:41 AM
