Greddy 310cc injectors
Old Apr 18, 2005 | 05:20 PM
Integra21's Avatar
Default Greddy 310cc injectors
hey, i have a 98 GSR with 18g greddy turbo kit
my question is, when should i look to upgrade my injectors? i only plan on making 250-260 whp. will that power max out my injectors?
im asking this because my power peaks at around 5500-6000 rpm. i know my cat and 2.25in exhaust has some effect on that but i was also wondering if i would need bigger injectors, if so, which ones?
thanks - kinda of a n00b question sry
Old Apr 18, 2005 | 05:55 PM
StolenTeg's Avatar
Default Re: Greddy 310cc injectors (Integra21)
310cc is good up to about 200whp, get some 550cc and you'll be set
Old Apr 18, 2005 | 06:12 PM
Integra21's Avatar
Default Re: Greddy 310cc injectors (StolenTeg)
well im making that on a stock kit on stock settings - why would greddy have included these injectors if they would nearly be maxed out from the get go?
anyone else?
also tuning with hondata s200b
Old Apr 19, 2005 | 08:16 AM
Integra21's Avatar
bump
Old Apr 19, 2005 | 09:06 AM
StolenTeg's Avatar
Your going to need bigger injector anyway, the 310cc will not be able to get you to 250whp
Old Apr 19, 2005 | 10:18 AM
Integra21's Avatar
well which ones should i get? and where?
Old Apr 19, 2005 | 10:50 AM
StolenTeg's Avatar
550cc is good enough, wiredspeedlad is a good place to buy from whose also FI sponsor
Old Apr 19, 2005 | 11:32 AM
Integra21's Avatar
since i have the greddy injectors now, should i just go with with greddy 550cc injectors?
i see that they have other fittings and stuff, would i need anything like that? or should the 310cc's just swap out for the 550cc's?
Old Apr 19, 2005 | 11:49 AM
-iLLuZioN-B18C1's Avatar
550s at least so you have room for improvement
Old Apr 19, 2005 | 01:05 PM
Integra21's Avatar
Default Re: Greddy 310cc injectors (-iLLuZioN-B18C1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra21 &raquo;</TD></TR><TR><TD CLASS="quote">since i have the greddy injectors now, should i just go with with greddy 550cc injectors?
i see that they have other fittings and stuff, would i need anything like that? or should the 310cc's just swap out for the 550cc's?</TD></TR></TABLE>
Old Apr 19, 2005 | 01:52 PM
StolenTeg's Avatar
The 550cc (RC) from wiredspeedlab will plug right in to the clip for your 310cc now
Old Apr 19, 2005 | 04:46 PM
Integra21's Avatar
StolenTeg - i PMed you for some info
what is the difference between saturated and Peak & Hold injectors? which one for me?
Old Apr 19, 2005 | 05:37 PM
Integra21's Avatar
so i would want the saturated ones?
Old Apr 21, 2005 | 06:56 PM
Integra21's Avatar
the RC (550cc) injectors will plug into my clip for my Greddy (310cc) injectors?
Old Apr 21, 2005 | 07:16 PM
Blown90hatcH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra21 &raquo;</TD></TR><TR><TD CLASS="quote">the RC (550cc) injectors will plug into my clip for my Greddy (310cc) injectors?</TD></TR></TABLE>Yes. Also contact Arturbo on here for precision injectors. Just get some saturated 550 injectors....RCs or Precisions and you will be set.
Old Apr 22, 2005 | 04:45 AM
Integra21's Avatar
Default Re: Greddy 310cc injectors (Blown90hatcH)
ok - well wiredspeedlab is running a H-T special for RC injectors for 280 shipped. so i think ill jump on that- are precisions any better?
Old Apr 22, 2005 | 10:32 AM
Sz28r's Avatar
Does going from 310cc injectors to 550cc require a change in the fuel pump????
Old Apr 22, 2005 | 01:08 PM
Integra21's Avatar
Default Re: Greddy 310cc injectors (Sz28r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sz28r &raquo;</TD></TR><TR><TD CLASS="quote">Does going from 310cc injectors to 550cc require a change in the fuel pump????</TD></TR></TABLE>
will i need to upgrade from a stock fuel pump? if so, which one?
Old Apr 22, 2005 | 01:12 PM
orangeturbogsr94's Avatar
hEY I IM'ED YOU
Old Apr 22, 2005 | 01:15 PM
IF YOU GET THE 550'S INJECTORS YOU SHOULD BUY A 255 WALBRO FUEL PUMP
I GOT THE INJECTORS BUT NEED THE FUEL PUMP BUT ILL SELL YOU THE INJECTORS.
Old Apr 22, 2005 | 01:23 PM
Integra21's Avatar
Walbro 255lph or 255lph HP??
Old Apr 22, 2005 | 01:43 PM
Integra21's Avatar
also if there is anything else i would need to do this right let me know... fuel rail..etc...
my set up:
18G greddy kit @7-8psi & intercooled -SBC-ID
3" thermal w/ test pipe
Hondata s200b w/ p28 ecu
stock internals and basically everything else
Old Apr 22, 2005 | 01:58 PM
nonvtecD's Avatar
No, you don't need to upgrade your fuel pump
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra21 &raquo;</TD></TR><TR><TD CLASS="quote">well im making that on a stock kit on stock settings - why would greddy have included these injectors if they would nearly be maxed out from the get go?
anyone else?
also tuning with hondata s200b</TD></TR></TABLE>
Because Greddy never intended your car to make very much power because then you'd blow it up and they'd have a lawsuit on their hands.
Old Apr 22, 2005 | 04:04 PM
Integra21's Avatar
Default Re: Greddy 310cc injectors (nonvtecD)
ok ive got one vote for change in stock fuel pump and one for no
btw - i will only run 550ccs and max of 8-9 psi (but most likely just 7psi)
so if you suggest upgrading the pump for room to grow, i will not need that extra room for bigger injectors, this is my DD and this is all i am going to do basically. just looking for around 250-260 whp
Old Apr 23, 2005 | 05:38 AM
Integra21's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra21 &raquo;</TD></TR><TR><TD CLASS="quote">ok ive got one vote for change in stock fuel pump and one for no
so if you suggest upgrading the pump for room to grow, i will not need that extra room for bigger injectors, this is my DD and this is all i am going to do basically. just looking for around 250-260 whp</TD></TR></TABLE>
