450 and smc+ before turbo???
Old Mar 15, 2003 | 09:04 AM
turbod16y8's Avatar
Default 450 and smc+ before turbo???
sup i did a search already and didnt come up with anything. im installing the new turbo next week and want to go ahead and install the 450cc and the smc. Can that be done? the car will be driven for a week before my turbo goes in. TIA
Old Mar 15, 2003 | 10:04 AM
see2k's Avatar
Default Re: 450 and smc+ before turbo??? (turbod16y8)
sure just make you sure you don't dump a lot of fuel at higher revs.. so you may have to tune the SMC a little to make sure that you're running like stock injectors until you get the turbo.
Old Mar 15, 2003 | 01:14 PM
GOLDBERG's Avatar
Default Re: 450 and smc+ before turbo??? (see2k)
i'd say install the smc first, with all settings turned to 0, then after that works, install the dsm's ...1 problem at a time, easier to diagnose if something goes wrong..wishing ihad done that now that my car dont start
Old Mar 15, 2003 | 01:37 PM
turbod16y8's Avatar
Default Re: 450 and smc+ before turbo??? (GOLDBERG)
if i install the smc and set it at 0 all the way. that would be just like stock right?
Old Mar 15, 2003 | 02:59 PM
see2k's Avatar
im not sure exactly.. i have a feeling if you zero it all out you'll get the equivalent to 0 cc injectors..
at the current moment, the injectors are -35% of 450cc dsm, which is the equivalent to 270 cc injectors.. stock injectors are 240cc.. anyways, im sure zip could help you out more.. i'd be very interested to know if your car doesn't srart when you install the 450cc injectors.
Old Mar 15, 2003 | 03:18 PM
zip's Avatar
zip
Correct, 0% correction on the SMCplus or SMC500 with stock injectors will be the same as running the stock fuel setup.
Old Mar 15, 2003 | 09:28 PM
turbod16y8's Avatar
Default Re: 450 and smc+ before turbo??? (zip)
got it to work drives like stock.
Old Mar 16, 2003 | 12:10 AM
GOLDBERG's Avatar
what about on the regular smc?
Old Mar 16, 2003 | 02:17 AM
zip's Avatar
zip
Yes, the same applies for the regular SMC.
Old Mar 19, 2003 | 02:39 PM
PoWeRBaN_PaNdA's Avatar
zip you have im
what fuel set up will running 440 or 450cc injectors at 0% correction yield?
Old Mar 20, 2003 | 01:39 AM
GOLDBERG's Avatar
Default Re: 450 and smc+ before turbo??? (powerban)
you cant run 440's on a honda with 0% correction...too much fuel yo
Old Mar 20, 2003 | 04:30 PM
thanks now i know yo , gotta learn somewhere
VTteg
May 7, 2006 06:19 AM
sasinorm01
Feb 24, 2006 03:13 PM
GSRfoedoe
Jun 1, 2005 07:07 AM
thumbtack
Dec 6, 2004 06:10 PM
MrCivic98
Feb 17, 2004 08:44 PM
