4 of 5 bolts on downpipe?
Old Apr 24, 2006 | 06:27 PM
huge230's Avatar
Default 4 of 5 bolts on downpipe?
I posted earlier about if the angle on my downpipe was too steep. My question now is what if i can only get 4 bolts on the downpipe because the angle prevents my 5th one from going on? I assume it will leak?
Old Apr 24, 2006 | 06:41 PM
veggiemaster's Avatar
Default Re: 4 of 5 bolts on downpipe? (huge230)
Yup. it sure will. I actually threaded in a stud and then put a nut on. Seems to work pretty well.
Old Apr 24, 2006 | 06:52 PM
raiden571's Avatar
Default Re: 4 of 5 bolts on downpipe? (veggiemaster)
which bolt is it?vtop or bottom, just curios
Old Apr 25, 2006 | 03:40 AM
huge230's Avatar
Default Re: 4 of 5 bolts on downpipe? (raiden571)
its the bottom bolt
Old Apr 25, 2006 | 04:17 AM
LoseRPunKx182's Avatar
mine's like that..i had to have the dp off the turbo about an inch where i can hand thread the nut in
Old Apr 25, 2006 | 04:31 AM
huge230's Avatar
Default Re: 4 of 5 bolts on downpipe? (LoseRPunKx182)
but you still use all 5?
Old Apr 25, 2006 | 06:08 AM
Boilermaker1's Avatar
I had this issue, we took a stud and shortened it a little bit, stuck it through the DP flange and threaded a mechanical lock nut on the back side of it between the flange and the pipe (effectively making a "bolt") then spun it into the turbine flange.... its working so far.
Old Apr 25, 2006 | 06:12 AM
huge230's Avatar
Default Re: (Boilermaker1)
thanks for the suggestion
Old Apr 25, 2006 | 08:35 AM
Default Re: (huge230)
yeah i have all 5 in...that's first nut to go on and last to come out
Old Apr 25, 2006 | 08:49 AM
Finland's Avatar
Default Re: (LoseRPunKx182)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LoseRPunKx182 &raquo;</TD></TR><TR><TD CLASS="quote">yeah i have all 5 in...that's first nut to go on and last to come out</TD></TR></TABLE>
boosteddb8904
Feb 1, 2008 09:00 AM
91_civicsi
Jul 23, 2007 10:43 PM
boostincoupe
Aug 3, 2006 09:20 PM
DubyaAye
Jun 27, 2004 08:07 AM
Meet07
May 7, 2004 12:28 PM
