5-bolt downpipe users...getting a bolt/stud/nut on the 5th bolt?
Old Aug 3, 2006 | 07:26 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default 5-bolt downpipe users...getting a bolt/stud/nut on the 5th bolt?
My current plan is to run 4 of the 5 bolts, and then run a 5-bolt flange gasket. How can I get a stud/nut on that 5th bolt of the downpipe? The bend is too sharp coming off of the flange, and I don't want to re-do my downpipe.
Old Aug 3, 2006 | 07:28 AM
Muckman's Avatar
Moderator in Chief
Default Re: 5-bolt downpipe users...getting a bolt/stud/nut on the 5th bolt? (boostincoupe)
Put a stud in the turbo and use a nut on the downpipe flange.
Old Aug 3, 2006 | 07:31 AM
nerdsports's Avatar
Default Re: 5-bolt downpipe users...getting a bolt/stud/nut on the 5th bolt? (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Put a stud in the turbo and use a nut on the downpipe flange.</TD></TR></TABLE>
Yep.
this is what happens when you go Bseries. just teasing (traitor).
Old Aug 3, 2006 | 08:02 AM
B18C Turbo's Avatar
i cant get a nut on mine, so i plugged the hole in the turbine housing with a stud so it wouldnt leak
Old Aug 3, 2006 | 08:08 AM
drintegra's Avatar
get a hex bolt. should fit fine, just make sure that it is not as long. It will be a bitch to tighten and loosen.
Old Aug 3, 2006 | 09:03 AM
TurboBA8's Avatar
Default Re: 5-bolt downpipe users...getting a bolt/stud/nut on the 5th bolt? (drintegra)
i have a similar problem with my dp. i had to buy a slightly shorter bolt. i put the short bolt in first so i can pull the dp away from the turbo a little bit and not have the head of the bolt smashed again the dp. then i put in the rest of the bolts.
Old Aug 3, 2006 | 09:12 AM
rudebwoy's Avatar
all I did was put a b16 exhaust stud in the turbo, and use the exhaust stud nut, but have to put that one in first.
or cut a slot in the flange hole thread the bolt half the way in the turbo and slide the flange on and tighten it down.
Old Aug 3, 2006 | 09:44 AM
SL0WEGG's Avatar
Default Re: (rudebwoy)
or you can just weld the flange to the turbo
Old Aug 3, 2006 | 11:51 AM
SPOOLINmatt's Avatar
Default Re: (boostedej1)
notch the bottom hole on the flange so it will slip over the bolt or stud then tighten and add the rest of the bolts.
Old Aug 3, 2006 | 01:04 PM
playahwitgame's Avatar
Default Re: (SPOOLINmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOOLINmatt &raquo;</TD></TR><TR><TD CLASS="quote">notch the bottom hole on the flange so it will slip over the bolt or stud then tighten and add the rest of the bolts.</TD></TR></TABLE>
exactly what i did. cut out a portion of the flange. tighten up the bolt, them slip the dp on top of it
Old Aug 3, 2006 | 01:30 PM
GENIUS!
Will it leak though?
Old Aug 3, 2006 | 01:31 PM
Default Re: 5-bolt downpipe users...getting a bolt/stud/nut on the 5th bolt? (nerdsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nerdsports &raquo;</TD></TR><TR><TD CLASS="quote">
Yep.
this is what happens when you go Bseries. just teasing (traitor). </TD></TR></TABLE>
You LOVE it!
Old Aug 3, 2006 | 02:15 PM
SL0WEGG's Avatar
Default Re: (boostincoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe &raquo;</TD></TR><TR><TD CLASS="quote">
GENIUS!
Will it leak though?</TD></TR></TABLE>
nope
Old Aug 3, 2006 | 03:43 PM
importdude2000's Avatar
Old Aug 3, 2006 | 09:12 PM
Default Re: (importdude2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importdude2000 &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
EXACTLY!!!
Old Aug 3, 2006 | 09:20 PM
EK k kay's Avatar
My downpipe was made with a bolt alright inserted.
playahwitgame
Jun 8, 2006 10:37 AM
huge230
Apr 25, 2006 08:49 AM
brent_G
Sep 8, 2005 03:19 PM
Acura_I-RS
Jul 31, 2003 02:43 PM
kenbdSi
Oct 27, 2002 10:03 AM
