3 inch DP
Old Sep 9, 2003 | 12:34 PM
TTWS6.
Guest
Posts: n/a
Default 3 inch DP
At what power levels is it necessary? is it over 400 or before that?
Old Sep 9, 2003 | 12:47 PM
Kack's Avatar
Default Re: 3 inch DP (TTWS6.)
well, most likely it will be a 2.5 in DP flared into a 3 in. Then 3 in all the way back. Ppl around here say 250 + hp go 3 in all the way.
My question is, there is still that restriction in the 2.5 portion of the DP? Its a bottleneck period. Does it even help much to go 3 in?
Old Sep 9, 2003 | 10:32 PM
SiR Kid's Avatar
New User
Default Re: 3 inch DP (Kack)
A 1/4" bottleneck coming out of a 2.5" turbine outlet isn't that much... If it steps up to 3" immediately, there is no bottleneck, really. If you use a 2.5" U bend to clear the A/C, THEN you go to a 3", that's not really helping much, maybe a little, but make sure you've got a 3" straight through exhaust after that to make use of it.
Old Sep 10, 2003 | 02:39 AM
superfuji57's Avatar
What if you have a cutout coming from the 3" portion? Will it make much of a difference over a 2.5" dp w/a cutout?
AzntaggeR
Mar 12, 2005 09:49 AM
Finest
Feb 26, 2005 03:09 PM
countryboy
Feb 10, 2005 12:24 PM
xxthabest1xx
Feb 22, 2004 06:42 PM
