3 inch Downpipe problems..
Old Mar 9, 2006 | 05:16 PM
Topdawgg's Avatar
Default 3 inch Downpipe problems..
Alright guys... Im havin a bit of a problem
Ive decided, after trying to buy a 4 bolt 3 inch downpipe, and not being able to find one on here... that Im going to have to build a custom one
now my problem is finding a flange that allows me to get a 3inch downpipe to my garrett t304e...
its a 2.5 inch exhaust outlet.. so i dont know how im gonna find somethin that I can use to make it go to a 3inch...
any feedback or help would be greatly appreciated
Old Mar 9, 2006 | 05:22 PM
KeyserSoze's Avatar
Default Re: 3 inch Downpipe problems.. (Topdawgg)
Why not just use a 2.5" 90 off of the turbine, then use a 2.5" to 3" reducer??
Edit: the reducer backwards of course......
And I assume what you are saying is that if you tried to use a 3" bend right off the bat it would be to large and maybe obstruct the holes to mount the dp on the turbine housing??
Old Mar 9, 2006 | 05:24 PM
NJIN BUILDR's Avatar
http://www.atpturbo.com/Mercha...e=FLS
93turbo16's Avatar
Default Re: 3 inch Downpipe problems.. (KeyserSoze)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KeyserSoze &raquo;</TD></TR><TR><TD CLASS="quote">Why not just use a 2.5" 90 off of the turbine, then use a 2.5" to 3" reducer??</TD></TR></TABLE>
Or whatever works for your application.
Old Mar 9, 2006 | 05:25 PM
KeyserSoze's Avatar
Default Re: 3 inch Downpipe problems.. (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">http://www.atpturbo.com/Mercha...e=FLS</TD></TR></TABLE>
Perfect, looks like problem solved.....
Old Mar 9, 2006 | 05:26 PM
Topdawgg's Avatar
well whats the difference between that and this?
Old Mar 9, 2006 | 05:38 PM
93turbo16's Avatar
That lets you hook up a vband connection for your downpipe. That is a slick piece.
Default Re: (Topdawgg)
That ones designed for a v-band clamp on the down pipe.Nice set-up but big money.
Glenn
Old Mar 9, 2006 | 06:12 PM
KeyserSoze's Avatar
Default Re: (NJIN BUILDR)
Dude, go with the v-band, that fitting is pretty sick....
Old Mar 9, 2006 | 06:25 PM
Topdawgg's Avatar
I have no idea what a Vband is... ive heard the term...
wow.. i feel lost tonight.. i need a beer
Old Mar 9, 2006 | 06:57 PM
StolenTeg's Avatar
You should go with a 2.5 inch&gt;3 inch because it gonna suck trying to bolt it done with the 3 inch pipe. I can only tighten 3 out of 4 bolt since there is no space to tighten the other cause it at the bend.
V band is highly recommended tho, it so easy to take off and put on
Old Mar 9, 2006 | 07:03 PM
adictionbass's Avatar
Default Re: (StolenTeg)
i just used a 3" pipe and dented it in where the bolts go. ill see if i have a pic
Old Mar 9, 2006 | 08:35 PM
B18C1CYA's Avatar
Default Re: (adictionbass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass &raquo;</TD></TR><TR><TD CLASS="quote">i just used a 3" pipe and dented it in where the bolts go. ill see if i have a pic</TD></TR></TABLE>
Thats what we do also , works great no need for a adapter
Old Mar 11, 2006 | 05:29 AM
quick_ls's Avatar
we used a agp flange and just welded u the 3 downpipe to it. We did have issues with the bolts not being tightened down because of the welds, but after some grinding, they fit perfect!
Vband is definetly better! i wish i would've went that route. I have to remove the turbo, manifold, and downpipe to install my EGT probe and its going to be a PAIN IN THE ***
Old Mar 11, 2006 | 06:09 AM
chrisgottigsr's Avatar
try http://www.spoolinperformance.....html
Old Mar 11, 2006 | 07:07 AM
JDM00SI's Avatar
i have one for sale....
will firt that perfectly...... pm me
Old Mar 11, 2006 | 09:07 AM
Jay_Sensing's Avatar
Vband is definately a sick setup, I just did the 2.5 90 and then went to 3 on my DP though and I have plenty of room to tq all my bolts so it is an option if you prefer the less expensive route.
But if I had it to do again, I would rock the Vband setup just for the ease since my stuff comes out and in often.
Old Mar 11, 2006 | 10:51 AM
Kelly.'s Avatar
I've quit using this account
same here
Old Mar 11, 2006 | 10:56 AM
blackeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topdawgg &raquo;</TD></TR><TR><TD CLASS="quote">well whats the difference between that and this?
spend the few extra bucks and buy this. i did, its completely worth it. 2.5" to 3" vband, then just weld the 3" vband right to your downpipe. it makes aligning the downpipe, fitting it on there and actually taking it on and off so easy its amazing. before this i was struggling with alan head bolts and i could only get 3/4 on there because of the downpipe bend, blablabla. this solved all my problems
roller3804
Feb 21, 2012 02:54 PM
JdmTypeRdc2
Mar 3, 2011 05:58 AM
Topdawgg
Feb 8, 2006 03:11 PM
itsJDMyo
Nov 28, 2005 08:03 PM
turbochargeb18c
Jun 14, 2005 01:32 PM
