3 bar map wiring
Old Mar 27, 2004 | 12:29 PM
whackassfawker's Avatar
Default 3 bar map wiring
I have a 98 integra and I want to make sure I wire this thing right Could anyone help? I searched however there is nothing listed for obd2 integra's
Old Mar 27, 2004 | 12:46 PM
sneakypete's Avatar
Default Re: 3 bar map wiring (Type R #0008)
Here you go.
A goes to ground (green and white on your wiring harness)
B goes to map signal (red and green)
C goes to 5v (yellow and red)
1996 and later Integras
Yellow/Red, 5V
Red/Green, Signal to ECU
Green/White, Ground
Old Mar 27, 2004 | 01:21 PM
mamaboy's Avatar
http://www.hondata.com/3barinstall.html
Old Mar 27, 2004 | 02:03 PM
Thanks I love you!!!
Old May 31, 2005 | 03:52 PM
dategb16vortech's Avatar
Default Re: (whackassfawker)
If you want to know the wiring for a GM 3 Bar Map (can run up to 29 PSI)
BTW this is for an OBD1 Wiring Harness
A- goes to the Green and White wire which is ground
B- goes to the white with a yellow stripe which is the map signal
C- goes to the yellow with a white stripe which is the 5V Power
BTW this is for an OBD2 Wiring Harness
B- goes to the red with a green stripe which is the map signal
C- goes to the yellow with a red stripe which is the 5V Power
Just a word for the wise:
GM 3 BAR MAP will work with Hondata but you need to have your datalogger set to GM 3 BAR MAP Voltage because the GM sensor runs on a different voltage than the stock Honda sensor. What I did with mine since I do not yet have datalogging is I grafted in the GM 3 BAR MAP onto my stock harness and then I will switch which MAP is plugged in when I go to get my motor tuned. This way I can run my stock one for now and then just unplug it and plug in the 3 bar when I go to get it tuned. Also if I ever want to sell the car but keep my 3 bar and Hondata I can just plug in the old MAP sensor
MMMGIRL
Mar 9, 2013 04:02 PM
00si2
Apr 12, 2009 04:52 PM
Kahuna9889
Apr 5, 2009 05:57 PM
soulo
Feb 27, 2008 09:03 AM
paul93sir
May 31, 2005 03:53 PM
