need help for wiring up a gm 3 bar map sensor
Old Aug 26, 2003 | 05:23 AM
paul93sir's Avatar
Default need help for wiring up a gm 3 bar map sensor
does anyone know which wires for a honda map sensor go on a gm 3 bar any help appreciated
paul
Old Aug 26, 2003 | 05:24 AM
ladysman's Avatar
Default Re: need help for wiring up a gm 3 bar map sensor (sir2t)
http://www.hondata.com/3barinstall.html
Old May 31, 2005 | 03:53 PM
dategb16vortech's Avatar
Default Re: need help for wiring up a gm 3 bar map sensor (ladysman)
If you want to know the wiring for a GM 3 Bar Map (can run up to 29 PSI)
BTW this is for an OBD1 Wiring Harness
A- goes to the Green and White wire which is ground
B- goes to the white with a yellow stripe which is the map signal
C- goes to the yellow with a white stripe which is the 5V Power
BTW this is for an OBD2 Wiring Harness
B- goes to the red with a green stripe which is the map signal
C- goes to the yellow with a red stripe which is the 5V Power
Just a word for the wise:
GM 3 BAR MAP will work with Hondata but you need to have your datalogger set to GM 3 BAR MAP Voltage because the GM sensor runs on a different voltage than the stock Honda sensor. What I did with mine since I do not yet have datalogging is I grafted in the GM 3 BAR MAP onto my stock harness and then I will switch which MAP is plugged in when I go to get my motor tuned. This way I can run my stock one for now and then just unplug it and plug in the 3 bar when I go to get it tuned. Also if I ever want to sell the car but keep my 3 bar and Hondata I can just plug in the old MAP sensor
92redhatch
Jan 12, 2007 01:25 PM
Toda Party
Oct 17, 2005 10:50 AM
nick-vti
Aug 10, 2004 09:27 PM
