3 bar map sensor
Old Jun 26, 2005 | 08:51 PM
redlseg's Avatar
Default 3 bar map sensor
does anyone know where to get one? and does it bolt up were the original map sensor is or do i have to mod something?
Old Jun 26, 2005 | 09:43 PM
redlseg's Avatar
Default Re: 3 bar map sensor (h-tman)
please some one help. at least post a pic up so i can get an idea of what to do
Old Jun 26, 2005 | 11:18 PM
Redline130's Avatar
You can get one from Summit Racing.
Old Jun 27, 2005 | 08:50 AM
redlseg's Avatar
Default Re: 3 bar map sensor (Redline130)
if i order it from Summit Racing does the 3 bar map sensor bolt right where the original map sensor is location?
Old Jun 27, 2005 | 09:06 AM
TheShodan's Avatar
Moderator
No. You must remove and block the original map location so that it sees no air, and rewire the 3 bar map sensor to its matching "pigtail" to work. Be warned!! Your engine managment must be able to recognize the the voltage signal from the 3 bar map sensor. it is not something you can just change using your stock ECU w/ no adjustment, or even a "chip".
Old Jun 27, 2005 | 09:19 AM
BoostedJeff's Avatar
Default Re: (TheShodan)
Call Evans Tuning, I got mine next day
Old Jun 27, 2005 | 10:27 AM
dustin's Avatar
http://www.lightningmotorsports.com/sveharness.htm
at the bottom. $62 w/ connector. and they are a H-T sponsor.
Old Jun 27, 2005 | 10:49 AM
EGP's Avatar
EGP
Do you have remove the old map sensor, can't you just leave it in the intake manifold and unplug it?
Old Jun 27, 2005 | 10:55 AM
dustin's Avatar
Default Re: (EGP)
You can leave it in.
Old Jul 28, 2005 | 08:29 PM
TurboTeG4's Avatar
Default Re: (dustin)
Can I hook the vacuum on the 3 bar sensor to my brake booster vacuum, which is also connected to my BOV?
Old Jul 29, 2005 | 10:07 AM
dustin's Avatar
Default Re: (TurboTeG4)
Yes.
young geezer
Aug 1, 2009 12:44 PM
eg:R
Dec 6, 2008 05:41 PM
turbolshatch
Feb 2, 2006 06:06 AM
joeyitr309
Oct 21, 2001 12:04 PM
