safely turning boost up...
Old Jul 28, 2005 | 09:01 PM
joshcivic00's Avatar
Default safely turning boost up...
how can i safely turn boost up on my 00civicEX greddy turbo kit with a manual boost controller,is there steps or procedures???also,can i do 7-8 PSI with the stock greddy stuff supplied(Emanage,injectors)???can i make around 160-180WHP with that pressure???
Old Jul 28, 2005 | 09:11 PM
a1320addict's Avatar
Default Re: safely turning boost up... (joshcivic00)
you need to be tuned for what boost pressure you are running to be safe.
Old Jul 29, 2005 | 05:01 AM
ginoboy1978's Avatar
I have a stock D16Y8, running 5lbs of boost and getting 180 WHP. And yes if you want to turn up the boost you have to get it re-tuned.
Our stock engine can handle 200WHP MAX....any more and there go your rods.
DAN
Old Jul 29, 2005 | 05:28 AM
Boosted96EK's Avatar
Default Re: safely turning boost up... (ginoboy1978)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ginoboy1978 &raquo;</TD></TR><TR><TD CLASS="quote">I have a stock D16Y8, running 5lbs of boost and getting 180 WHP. And yes if you want to turn up the boost you have to get it re-tuned.
DAN</TD></TR></TABLE>
I wouldnt go by that per say... There are a lot of ppl making well over 200whp w/ stock d-series motors that are holding up just fine.. Now Im pretty much in the same predicament... If I were you (and this is the way I plan on doing it in my personal car) I'd spend a little more money and get an electronic boost controller. Im a firm believer that our stock blocks can handle more than 200whp but I wouldnt want to run more boost than I am right now (7psi) constantly... atleast not during the day with 95* heat and near 100% humidity.. If I was at the track or it was cool out (typically at night) I wouldnt mind running a bit more boost to make more power as long as the tune is good... The adjustablity between low and high boost is something you dont have with a manual boost controller... Not only that I believe some have feature to help with spikes...
Old Jul 29, 2005 | 06:13 AM
Default Re: safely turning boost up... (Boosted96EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted96EK &raquo;</TD></TR><TR><TD CLASS="quote">
I wouldnt go by that per say... There are a lot of ppl making well over 200whp w/ stock d-series motors that are holding up just fine.. Now Im pretty much in the same predicament... If I were you (and this is the way I plan on doing it in my personal car) I'd spend a little more money and get an electronic boost controller. Im a firm believer that our stock blocks can handle more than 200whp but I wouldnt want to run more boost than I am right now (7psi) constantly... atleast not during the day with 95* heat and near 100% humidity.. If I was at the track or it was cool out (typically at night) I wouldnt mind running a bit more boost to make more power as long as the tune is good... The adjustablity between low and high boost is something you dont have with a manual boost controller... Not only that I believe some have feature to help with spikes...</TD></TR></TABLE>
I agree Boosted96EK... there are people running more than 200whp on the stock block. What I meant to say is that you can run up to 200whp safely. My tuner didn't want me to go any higher....so i trusted him and stayed @ 180whp.
DAN
Old Jul 29, 2005 | 07:34 AM
1boostedcivic's Avatar
250whp with a good motor and good tune. They wont last long though, but 6months - year of that power is well worth it.
Old Jul 29, 2005 | 09:41 AM
Default Re: safely turning boost up... (1boostedcivic)
I believe BBKA has been at 235ish for over a year running 12's
Old Jul 29, 2005 | 10:57 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted96EK &raquo;</TD></TR><TR><TD CLASS="quote">I believe BBKA has been at 235ish for over a year running 12's</TD></TR></TABLE>
Damn........your tempting me to turn up my boost now.....lol.
DAN
VtecKiDD
Nov 18, 2006 03:54 PM
99lspwr
Mar 18, 2004 02:07 PM
93TurboSi
Oct 16, 2003 06:04 PM
