3 bar map off stock location...
I was searching for one of those pieces that you place over the stock map sensor location which then has a nipple on it so you can run an external map sensor off the stock location.
Can someone point me in the right direction?
Re: 3 bar map off stock location... (MooreBoost)
Mr. Badwrench
Re: 3 bar map off stock location... (non-VTEC)
with the exception of mine, all the tuning we have done has been with hondata with the stock map up to 11 psi. i have a jdm b16 and the map is remotely mounted so the 3 bar isnt an issue.
Re: 3 bar map off stock location... (boostedcivicsir)
Thanks for the Props guys.
I came up with this design after seeing the map voltage boucing around while tuning a car with big injectors. This made the drivabilty much smoother as it takes the source from Hondas location.
Re: 3 bar map off stock location... (Jordo@KAP)
couldn't you just leave the stock map sensor there and use a T to get vac from elsewhere and save yourself 20 bucks . but then again 20 dollars isnt very much money
projectjazzmine
Engine Management and Tuning
06-10-2008 09:38 AM
