GM 3BAR MAP SENSOR !ALREADY SEARCHED!
Old Feb 25, 2004 | 07:33 AM
BEASTLY's Avatar
Default GM 3BAR MAP SENSOR !ALREADY SEARCHED!
New here but yes i did try to find out in search. Im trying to run more boost in my hatch, ive bought two GM map sensors both made my hatch run worse. Im wondering is there a certain GM map sensor that I need. Ive tried 98 cavilers and a 90 pick-up
Old Feb 25, 2004 | 07:40 AM
Silverbeast's Avatar
Default Re: GM 3BAR MAP SENSOR !ALREADY SEARCHED! (BEASTLY)
What engine mgmt are you running?
Old Feb 25, 2004 | 08:26 AM
JDogg's Avatar
Default Re: GM 3BAR MAP SENSOR !ALREADY SEARCHED! (Silverbeast)
you cant just slap on the map sensor and hope it works... you have to rescale the fuel/ign maps to take advantage of the increased rang of the map sensor
Old Feb 25, 2004 | 08:31 AM
V-SPEC 1's Avatar
You can get the 3 bar map from a camaro the last edition. And you need the pigtail with it.
Old Feb 25, 2004 | 08:36 AM
BEASTLY's Avatar
Default Re: GM 3BAR MAP SENSOR !ALREADY SEARCHED! (boostedb20vtec)
Thanks......not sure what a pigtail is though, the map sensor plug from a GM???? if so i got that.
Old Feb 25, 2004 | 09:06 AM
You cant simply hook the 3 bar up to a stock ecu... EVEN if you have the vafc hack it still runs like ****. Are you running Hondata, AEM EMS, Uberdata... any sort of engine mgmt?
Old Feb 25, 2004 | 09:43 AM
DaX's Avatar
DaX
Loved
Community Favorite
Buy your 3 bar from either Motec or Hondata [who sources them from Motec]. There were 3 different 3 bar map sensors made [i think] and only one of them will work properly.
Old Feb 25, 2004 | 09:56 AM
BEASTLY's Avatar
Default Re: (DaX)
Well my car runs fine with stock map sensor, but im planning on running alot more boost pretty soon, and i know of people who use it. I talked to norris from nu image at MIR awhile ago and he showed me that he was using one. My fuel and everything is good until i put the GM sensor on and it bugged out so i changed that ****.
mike1114's Avatar
Default Re: (DaX)
yea and like everyone keeps saying, if your using hondata or AEM EMS or even vtec hack you need to re-calibrate them to work with the 3 bar sensor.
Old Feb 25, 2004 | 09:57 AM
92HB_HB's Avatar
Default Re: (DaX)
i'm assuming the "pigtail" is the wiring harness plug??
Old Feb 25, 2004 | 10:19 AM
BEASTLY's Avatar
Default Re: (92HB_HB)
i was thinking that too, i got the "pigtail" and i spliced it into my harness and plugged it up, it started fine idled fine with the 90's truck sensor the caviler would start and cut right off when i used it, as far as driving goes the beast goes to about 3 grand then the breaking up starts, so i was like forget it plugged my old one back up.
Old Feb 25, 2004 | 10:31 AM
turbo*s2k's Avatar
Default Re: (BEASTLY)
Helpless!
Read the previous posts!
Old Feb 25, 2004 | 10:35 AM
READ HERE!!!!
If you dont get the solution now, then you are hopeless.
Old Feb 25, 2004 | 10:55 AM
M.A.R.C.'s Avatar
Default Re: (Silverbeast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silverbeast &raquo;</TD></TR><TR><TD CLASS="quote">READ HERE!!!!
If you dont get the solution now, then you are hopeless.</TD></TR></TABLE>
::falls off chair laughing::
sorry couldn't help myself
Old Feb 25, 2004 | 10:59 AM
BEASTLY's Avatar
Default Re: (CivicRyda2k)
shut the **** up, ur input wasnt needed. those that helped me with the problem thanks. Those who talk negative **** shut the **** up.
Old Feb 25, 2004 | 11:06 AM
DaX's Avatar
DaX
Loved
Community Favorite
Mighty big words for a mighty small post count. It appeared that you either:
a) were ignoring his comment
b) are too dense to understand
c) just skimmed over the post and didn't read his comment
You haven't told us at all what kind of EMS you're running, if any. We can't help you unless we know what you're working with.
Old Feb 25, 2004 | 11:12 AM
M.A.R.C.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BEASTLY &raquo;</TD></TR><TR><TD CLASS="quote">shut the **** up, ur input wasnt needed. those that helped me with the problem thanks. Those who talk negative **** shut the **** up.</TD></TR></TABLE>
hahahahaha. are you gonna dry your tears now? lmao
Old Feb 25, 2004 | 11:14 AM
DC2R714's Avatar
Default Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote">
You haven't told us at all what kind of EMS you're running, if any.</TD></TR></TABLE>
I smell stock ecu
Old Feb 25, 2004 | 11:21 AM
slowman's Avatar
I took way too long
Default Re: (DC2R714)
I'm running full GM ECU with a GM 2 bar map sensor. OMG makes tuning hella easy.
Old Feb 26, 2004 | 06:57 AM
BEASTLY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote">Mighty big words for a mighty small post count. It appeared that you either:
You haven't told us at all what kind of EMS you're running, if any. We can't help you unless we know what you're working with.</TD></TR></TABLE>
Like there is an importance of users by there post count. i used the post to get a question i had answered, isn't that what this is for? have some ****** manners and dont talk **** when someone is using this place for its intended use. your stupid *** responses mean one of three things:
a) you're a homo who has no life so he talks **** over the internet
b) your only friends are HT members and you are showing off for them
c) you never get ***** so you try and reach a level of satisfaction by letting out aggression on people who don't deserve to be fucked with
chill out ******s posts over....go cyber with some gay guys
Old Feb 26, 2004 | 07:08 AM
M.A.R.C.'s Avatar
In...
Old Feb 26, 2004 | 07:13 AM
Burke's Avatar
Banned
so what kind of management???
Old Feb 26, 2004 | 07:19 AM
chill out ******s posts over....go cyber with some gay guys </TD></TR></TABLE>
Did you have a valid question, or did you want to start posting on an actual gay forum known as Clubsi.com ?
Old Feb 26, 2004 | 10:49 AM
DaX's Avatar
DaX
Loved
Community Favorite
Are you done yet? Now can we talk about hondas? So, back to my question, what EMS do you have?
Old Feb 26, 2004 | 01:00 PM
whackassfawker's Avatar
I bet most suffer from reason number two. It's pathetic but what are you going to do. Unless you're using a quality ems then there should be no need for more than 11psi.
