2nd try at boost!!!
Old Aug 28, 2005 | 05:03 PM
spooned out's Avatar
Default 2nd try at boost!!!
First attempt was civic si b16a+used greddy kit (low mileage) ...never got it to work right so i scrapped/sold that and stayed N/A for 4yrs or so till now....
2nd attempt:
Jdm 97b18c + lsd + civic si eg
Blox intake mani + hondata gasket
rebuilt garrett t3/04b .70compressor .63 turbine
Spooling perf log mani
Spooling per 2.5 dp + dumptube rerouted
27x9x2.5 bar&plate ic
2.5 ic piping
Flamco T oil feed/return kit
Tial 38mm 7.25 psi
greddy bov
Hondata s200
rc550 saturated
walbro 255
This is a daily driven car so im not looking for big numbers. my guess is atleast 230-240 from the setup i have now. won't knoe until i get it tuned/dynoed probably within 4wks....hopefully this will go alot better then my first attempt... anything i'm missing feel free to comment.....
Modified by spooned out at 2:24 AM 8/29/2005
Modified by spooned out at 2:57 AM 8/29/2005
Old Aug 28, 2005 | 05:18 PM
playboyace35's Avatar
Default Re: 2nd try at boost!!! (spooned out)
hehe what psi are u goin to boost? cuz ur goin to get way higher than 230 hp lol
Old Aug 28, 2005 | 05:24 PM
Default Re: 2nd try at boost!!! (playboyace35)
maybe i should have said 7.25 psi not 7.25 spring haha thanks :fixed:
Old Aug 28, 2005 | 05:27 PM
SlowB16si's Avatar
You should make more then 230, Maybe around 250? set-up looks solid though, hope it works out for you
Old Aug 28, 2005 | 07:02 PM
Default Re: 2nd try at boost!!! (SlowB16si)
it be great if i hit 250..... any opinions on the turbo i knoe there are better suited ones out there but any opinions on it and the hot side 2.5" ic piping?
Old Aug 28, 2005 | 07:53 PM
wantboost's Avatar
Who is Mr Robot?
te/t04b would make around 220 at tha boost level, give or take. it took a buddy of mine 19psi on one to reach 300whp on an 83mm b16
Old Aug 28, 2005 | 07:55 PM
ccivic's Avatar
Default Re: 2nd try at boost!!! (wantboost)
... and this is a b18. I'd say around 250 well tuned.
Old Aug 28, 2005 | 07:56 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: 2nd try at boost!!! (ccivic)
at 10psi or so... not 7, its not an e, its a b. and b's suck at making power at low boost levels
Old Aug 28, 2005 | 09:12 PM
BoOsTiN Dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spooned out &raquo;</TD></TR><TR><TD CLASS="quote">First attempt was civic si b16a+used greddy kit (low mileage) ...never got it to work right so i scrapped/sold that and stayed N/A for 4yrs or so till now....
2nd attempt:
2.5 ic piping
Tial 38mm 7.25 psi
greddy bov
Hondata s200
rc550 saturated
walbro 255
Modified by spooned out at 2:57 AM 8/29/2005</TD></TR></TABLE>
The 1st attempt wasnt good probably because you didnt have any engine management before? 4 years ago there was a lot of people just bolting on a turbo kit and go, no tuning and stuff.
Old Aug 28, 2005 | 10:51 PM
darkdayz's Avatar
Default Re: 2nd try at boost!!! (tRaCeBuStA)
I guess in 4 weeks or so I'll have to go out lookin for some prey to feed on....lol
Naw buddy you should be makin like everyone is sayin at least 230 ish and more power and good luck, I'm happy as hell and now maybe your bro's will follow in your foot steps
Old Aug 29, 2005 | 07:09 AM
HiProfile's Avatar
Default Re: 2nd try at boost!!! (darkdayz)
This guy comes to mind http://itrca.com/gallery/JanNiemi/index.php, can't remember his personal page with more info & vids.
IMO you won't really need the pump for just 230, but good if you ever build the motor. With that sort of CR though, don't push it, at least before it's tuned very well.
Old Aug 29, 2005 | 12:27 PM
TheShodan's Avatar
Moderator
Default Re: 2nd try at boost!!! (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">This guy comes to mind http://itrca.com/gallery/JanNiemi/index.php, can't remember his personal page with more info & vids.
IMO you won't really need the pump for just 230, but good if you ever build the motor. With that sort of CR though, don't push it, at least before it's tuned very well.</TD></TR></TABLE>
Ah yes. Boondock Saint... That's his name here on this site. Really good guy to talk to, and is a fellow Forced Fed Detroit Boost Addict
Old Aug 29, 2005 | 01:52 PM
Default Re: 2nd try at boost!!! (TheShodan)
hahah yeah they're allready drewling over phils craftsmanship but that hasn't made them cross over from n/a YET!......... yeah i knoe the B's don't perform as well as the E's etc...but ima see how far i can take this turbo before i change out... the first attempt was with the greddy (99si) blue box, i believe it was my wiring which cause it not to function properly... oyeah my stock pump has got 207xxx miles on it allready.... i think its alittle tired by now
on a side note:
Say it takes 10psi to make 250 on a t3/04B and 7psi to make 250 on an t3/04E is it safe to say that with the "B" more stress is put on the motor because its working harder to make 250 at 10psi vs the "E" at 7psi? or is the wear and tear on the motor the same instead its the turbo thats working harder?
Modified by spooned out at 11:30 PM 8/29/2005
spooned out
Sep 12, 2005 06:17 PM
abmerop18
Jun 24, 2005 01:30 PM
ScrapinSi
Jun 4, 2004 10:35 AM
TurboB18C1
Sep 22, 2003 11:25 AM
bluebullet
Jun 9, 2003 11:23 AM
