2nd gen dsm boost controller?
Old Sep 15, 2003 | 04:22 PM
Dsm634's Avatar
LOUD NOISES
Default 2nd gen dsm boost controller?
Does anyone know if the 2nd gen eclipse turbo's (specifically '97) have an electronic boost controller stock? I was just wonder because I recently had a turbo xs manual boost controller installed and the boost continues to taper off and sort of lag. Anyway any info would be much appreciated. Thanks
Old Sep 15, 2003 | 04:36 PM
greekspeed's Avatar
Default Re: 2nd gen dsm boost controller? (Dsm634)
uhhh u own a dsm or honda? i think the stock 2nd gen boost controller is electronic but not adjustable or anything like that...
but i dont think it will work in a honda...(if thats what ur asking)
Old Sep 15, 2003 | 04:39 PM
spike's Avatar
Default Re: 2nd gen dsm boost controller? (greekspeed)
they have a boost selenoid .. but not a boost controller. that i know of.
Old Sep 15, 2003 | 04:59 PM
Adriano's Avatar
Default Re: 2nd gen dsm boost controller? (spike)
I own a 95 tsi. No factory boost controller (electronic or manual)
Old Sep 15, 2003 | 05:08 PM
greekspeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spike &raquo;</TD></TR><TR><TD CLASS="quote">they have a boost selenoid .. but not a boost controller. that i know of.</TD></TR></TABLE>
ahh wella boost selenoid is pretty much a boost controller that cant be adjusted... forgot the "official" name..
well isnt it electronic by the fact that it plugs into the wiring harness and the selenoid is controlled that way..... i could be wrong (and porbably am. )
Old Sep 15, 2003 | 06:47 PM
Dsm634's Avatar
LOUD NOISES
Thanks for the help and info. The reason I was inquiring was to see if it was possible to remove this boost solenoid, therefore eliminating boost taper. It seems as if this solenoid is restricting the boost. Any ideas? And yeah its a dsm (obviously from first post).
Old Sep 15, 2003 | 09:58 PM
rioninja's Avatar
I dont know the details, but from reading DSM boards i can tell you that yes, it does have a boost "limiter" solenoid. I would search a few dsm boards, its a common mod to disable this, from what i understand.
Old Sep 16, 2003 | 09:13 AM
Dsm634's Avatar
LOUD NOISES
Thanks
Old Sep 16, 2003 | 09:26 AM
Signal Auto's Avatar
Yeh it does have a BCS (boost control solenoid) and a boost controller... if you have an AEM ems
Old Sep 16, 2003 | 09:29 AM
99blusi's Avatar
Default Re: 2nd gen dsm boost controller? (Signal Auto)
The boost control solenoid can be removed...in fact, I removed it and put my Joe P MBC in it's place (gen 1 but it's the same)
Old Sep 16, 2003 | 07:43 PM
Dsm634's Avatar
LOUD NOISES
Any idea where it is or what it looks like? The stupid thing makes the boost needle jump around and the car jerk like I'm shifting every two seconds.
Old Sep 17, 2003 | 03:56 AM
spike's Avatar
hmm.. maybe you can help us with this one.. we put the green turbo on my buddy's 97 gst, and we tried like hell to crank up the boost.. measured it at the compressor housing and mani.. no matter what it would not boost past 15 psi.. (16 psi at compressor housing) even disconnecting the vacuum line from the wastegate! We figured must be a faulty wastegate flapper or something (it's internally gated). any other ideas?
Old Sep 17, 2003 | 07:01 AM
Adriano's Avatar
DSM634...you should really check out machv.com, dsmtalk.com, dsntuners.com. You will get more answers there. As for you question, There should be a vacuum line on your conpressor, folow that line to the bcs (boost control solenoid. It's right under you MAS sensor (where your intake filter is). It's black and has 2 hoses with a plug. It's easy.
Old Sep 17, 2003 | 08:20 AM
Dsm634's Avatar
LOUD NOISES
Thanks, much appreciated
Old Sep 22, 2003 | 04:14 PM
Boltz's Avatar
god damnit boltz, why would you ever buy an eastermaro?
S2Kustom
Honda S2000
Sep 26, 2008 09:02 AM
97turboteg
Apr 11, 2006 10:47 PM
boostincoupe
Jul 4, 2003 04:07 AM
mikelcrx
Jul 4, 2002 10:20 PM
