238 compression
Old Feb 13, 2005 | 09:23 PM
NORCALCVC's Avatar
Default 238 compression
just got a quick question. is this normal for a ls block w/ 84mm je flat top
9:1 piston to have 238 compression on a stock gsr head that has been milled .001. I was expecting somthing like 195 or 200. any intelligent answer is appreciated. The 238 compression seemed a little too high. The piston was and did look like 9:1.
Old Feb 13, 2005 | 09:44 PM
W O T's Avatar
Default Re: 238 compression (NORCALCVC)
Ive had a comp tester throw my stock A6 165 across the board and another shitty one run 195-200. they seem to vary
Old Feb 13, 2005 | 09:45 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: 238 compression (W O T)
is the block freshly built?
Old Feb 13, 2005 | 10:44 PM
*Boostwerks*'s Avatar
What engine was the 9:1 rated for?
The GSR head has quench pads that will raise the compression.
Old Feb 14, 2005 | 12:24 AM
NORCALCVC's Avatar
Default Re: (Bryson)
engine was 95 ls b18b1 block. block is freshly built by benson.
Old Feb 14, 2005 | 12:39 AM
shadow103rd's Avatar
Default Re: (NORCALCVC)
You just have a good Seal thats all!
to Benson!
Old Feb 14, 2005 | 01:26 AM
NORCALCVC's Avatar
Default Re: (shadow103rd)
yeah, you are right. Benson did a great job! That's after breaking it in with ACCEL ND SAE 30 oil. Vacuum on it was 23. Motor has 241 miles on it. The rings looked to be seated as well. First 35 miles on it was pure accelerating and decelerating. I might quick throttle response. With lugging. Putting load onto it. The rest was normal driving with occassional smooth acceleration to 7k rpm. The motor runs really well. I will change oil to stock honda 10w30 unitl 750 miles or so then go dyno my car. Everyone thanks for the info. just want to see if anyone had experience with high comp. numbers.
eg:R
Oct 18, 2007 05:56 PM
mikemskater
Apr 8, 2007 08:05 PM
hioutput
Jun 12, 2005 09:19 AM
ctegsta
Aug 8, 2004 11:04 PM
swlabhot
Sep 1, 2003 10:51 AM
