200whp LS-t?
Old Jul 31, 2009 | 01:40 PM
moofs's Avatar
Default 200whp LS-t?
What kinda of turbo or parts would be needed for this?
I was thinking a T-25 or maybe a DSM turbo and injectors?
This will be my daily so 200-220whp on the stock motor is my goal and a high 13 sec 1/4.
What would you recommend?
I've seen kits with T25's but I feel I can piece a cheaper one together.
Old Jul 31, 2009 | 03:44 PM
motormike40's Avatar
Default Re: 200whp LS-t?
You can have a reliable daily driven honda at 300whp if the engine is healthy (compression and leakdown test), use the correct boost parts, and get a good tune. No reason to shoot that low of whp. Piece together your own. you are right it'll be cheaper. **** the t25, way too small, it'll run out of breath at that 8k redline, look at t3/t4's 57, 60 trims and t3/t04e 57 trim, there are also a few others you can run, but those are tried and true and can be scoped at a decent price. The dsm 450's will take you to about 275 whp, if you want 300 whp I'd suggest 550cc. I'm running a t3/t3 60 trim and .48 hotside upwards 300 whp at 12 psi and daily drive the **** out of my gsr integra.
Old Jul 31, 2009 | 09:03 PM
LightningTeg's Avatar
Community Builder
If you only want 200whp just get the greddy kit with an intercooler and call it a day.
Old Aug 1, 2009 | 09:49 AM
em1si's Avatar
^lol..so true
Old Aug 2, 2009 | 07:55 AM
teg racer 877's Avatar
he said ls.. 300whp ls is not a good dd.. you should read a bit b4 u post. u would need to run at least 13-14 psi for that. and thats not very safe for a stock ls.
op, 240-260 whp is perfectly atainable and safe for a dd. on 9-11 psi, youl be happy. my advice is get a kit and spens the money on a good ems. hondata s300.
my setup:
stock 01 ls
garett 57 trim 11 psi
255whp
hondata s300
Old Aug 2, 2009 | 08:49 AM
blackeg's Avatar
dont get a t25 please. i feel its way to small, even for a low boost setup. i dont think theres any reason to go with something smaller than a t3 60 trim. even a t3t4 50 trim with a .48 exhaust will have full 10 psi by around 3200-3500. it will hold till redline and make like 225-250 give or take. plently for a daily setup and enough to make u go buy a good tire up front.
Old Aug 3, 2009 | 11:21 PM
moofs's Avatar
yea, 250whp would be PERFECT.
oemDC2
Nov 25, 2003 03:44 AM
EH2LS
Jun 2, 2003 07:07 PM
92HB_HB
May 9, 2003 09:35 AM
95lsteg
Mar 26, 2003 05:14 PM
PWRVTEC
Oct 9, 2002 12:05 PM
