2-step? what is it?
2-step? what is it?
Re: 2-step? what is it? (VTEC_PRODUCTION)
It's a dance for people that can't dance.
It's basically a temporary rev limiter (set lower than normal) used to aid in launching.
Re: 2-step? what is it? (t0p_sh0tta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0p_sh0tta »</TD></TR><TR><TD CLASS="quote">It's a dance for people that can't dance.
It's basically a temporary rev limiter (set lower than normal) used to aid in launching.</TD></TR></TABLE>
haha ok good one...but why is it so hella loud?
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC_PRODUCTION »</TD></TR><TR><TD CLASS="quote">
haha ok good one...but why is it so hella loud?</TD></TR></TABLE>
It's not the two step that's loud, it's propable the straight pipe or open header they're running.
It's loud because it's not 2-step, it's anti-lag.
2-step is just a rev-limiter that is set up to let you launch at a high RPM. Anti-lag adds a timing retard to your 2-step that essentially retards the timing until the exhaust valves are open, causing an uncontrolled explosion that greatly elevates the temperature and pressure in your exhaust manifold, effectively spooling your turbo and building boost with no engine load. I have used it before on my car, it sounds like someone chucked a bunch of hand grenades into your motor. It will scare the crap out of you if you're not expecting it.
Re: 2-step? what is it? (rmcdaniels)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rmcdaniels »</TD></TR><TR><TD CLASS="quote">It's loud because it's not 2-step, it's anti-lag.
2-step is just a rev-limiter that is set up to let you launch at a high RPM. Anti-lag adds a timing retard to your 2-step that essentially retards the timing until the exhaust valves are open, causing an uncontrolled explosion that greatly elevates the temperature and pressure in your exhaust manifold, effectively spooling your turbo and building boost with no engine load. I have used it before on my car, it sounds like someone chucked a bunch of hand grenades into your motor. It will scare the crap out of you if you're not expecting it.</TD></TR></TABLE>
it will defitnitly make the crowd at street races jump back.
HT's TOP CHEF
Re: (boost4life)
Perfect explanation.
Now hows it turned off? Some sort of motion sensitive sensor that detects when the car's clutch has been engaged? or when the car starts to move at any point?
* B A N N E D *
Re: (97Ej6mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike »</TD></TR><TR><TD CLASS="quote">Now hows it turned off? Some sort of motion sensitive sensor that detects when the car's clutch has been engaged? or when the car starts to move at any point?</TD></TR></TABLE>
on my friends race car he has a button on the shift ****, when he holds it down, it engages the 2step, but when he releases, the car goes back to regular
Re: (97Ej6mike)
Pretty much any kind of switch will do it, some people mount a switch on the clutch pedal assembly. I have a programmable ECU, so you can just tell it that anti-lag is on at any RPM over xxxx while speed is 0.
