2 step, boost doesn't build
Old Jan 17, 2009 | 10:55 PM
91crxturbo's Avatar
Default 2 step, boost doesn't build
Hello, i have a 2 step setup and i do not build boost while holding the rpm's at 4500(b16, ball bearing turbo). Anyone know why?
Old Jan 17, 2009 | 10:58 PM
Redline130's Avatar
Default Re: 2 step, boost doesn't build
Are you confusing a 2 step with anti-lag?
Old Jan 17, 2009 | 11:01 PM
Ls_dx's Avatar
yeah thats what I was gonna say too.. You can rev it all day with no load on the motor and it wont build boost.. now anti-lag is another story..
Old Jan 17, 2009 | 11:32 PM
HiProfile's Avatar
Most ECU code for 2-step (on a Honda) will limit RPM by fuel cut. At that point, your motor is simply blowing warm air into the turbine - not enough to do anything. If it works by ignition cut it will help make some boost; with anti-lag, it will build a ton. Anti-lag is when your ECU retards the timing to a crazy extent, and dumps in 25-50% more fuel than needed. That burns the fuel as it enters the turbo; push exploding gasoline into a turbine, and it spins it like hell.
Old Jan 18, 2009 | 06:35 AM
96 GSR-T's Avatar
Dont know what size turbo you got, but 4500rpm with a B16 is not going to build much if any boost.
jdm_prelude19
Feb 4, 2011 02:28 PM
1sikhatch
Jul 8, 2010 01:38 PM
projectef
15
Jul 9, 2007 04:42 PM
Hoodwinked
Sep 2, 2003 06:37 PM
Tomakit
Dec 10, 2001 10:43 AM
