Race Gas Tuning / Pump gas w/ s200 and saving both tunes.......
I know there are several ways to prob do this but with me keeping the s 200 I believe I have to manually take a chip out to switch the tunes. Can any one else enlite me with more info on how to have your car tuned on Race Gas and Pump Gas w/ the s200 and have both tunes saved.
What do i need for this?
And around how much is it?
Re: Race Gas Tuning / Pump gas w/ s200 and saving both tunes....... (spoolingb20)
If your doing to different boost setting, one lower boost (pump gas) one higher boost (race gas). You dont need two different chips just remember to add the gas before you turn it up and keep the high boost chip in it.
Re: Race Gas Tuning / Pump gas w/ s200 and saving both tunes....... (10secivic)
That's what I try to do, Pump gas upto say...14 psi ( depending on alot of things) then race gas from 18 psi and up. That way you don;t need 2 chips and have to F around changing them.
http://www.moates.net/2timer-p-80.html
Allows you to burn 2 programs on one chip and switch between the 2 programs.
Re: Race Gas Tuning / Pump gas w/ s200 and saving both tunes....... (CRVRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRVRX »</TD></TR><TR><TD CLASS="quote">That's what I try to do, Pump gas upto say...14 psi ( depending on alot of things) then race gas from 18 psi and up. That way you don;t need 2 chips and have to F around changing them.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Clutch101 »</TD></TR><TR><TD CLASS="quote">http://www.moates.net/2timer-p-80.html
Allows you to burn 2 programs on one chip and switch between the 2 programs. </TD></TR></TABLE>
+1
+1
Nextelbuddy
05-05-2004 10:53 PM
