2.0L 15-20 lbs......1 gallon cell enough for a run?
Re: 2.0L 15-20 lbs......1 gallon cell enough for a run? (Pelican)
The aeromotive pump I have is rated at something like 700 HP, and it takes about a minute to pump a gallon of gas.
Re: 2.0L 15-20 lbs......1 gallon cell enough for a run? (Brian_92GSR)
liam
Re: 2.0L 15-20 lbs......1 gallon cell enough for a run? (liam821)
1 gallone fuel cell should get you donw the track at least 2 twice and back to return road and idleing all that jazz i use a custom one designed by tony1 on here and it works great 1 gallon fits where the battery location goes. Ask him he can make you one.
I know that this is out of subject but what is the difference between the a 96crv motor and a 96 b18b motor?Will my ls turbo kit fit onto the head?Do i have to use a different harness for ecu or is it plug an play?Just want to know if i'll run into prblems.Don't want to go vtech yet.
Lsr37
Lsr37
Re: 2.0L 15-20 lbs......1 gallon cell enough for a run? (b18bturbo)
Re: 2.0L 15-20 lbs......1 gallon cell enough for a run? (vtecdoc)
holy cow, how much weight does this save? i can't remember how much fuel weighs per gallon, but isn't water 8lbs. per. 1 gallon?
dephtone
24
05-17-2011 05:19 AM
Zer0skll
04-15-2007 08:35 PM
