1g bov question
Old Aug 18, 2003 | 02:09 PM
InTeGrA B18b1's Avatar
Default 1g bov question
my 1g bov seems like its not working. i have a good vacuum source. i just cant hear anything. Is the bov not loud?or you think the bov is opening up too slow
thanks
Old Aug 18, 2003 | 06:44 PM
Default Re: 1g bov question (InTeGrA B18b1)
anyone
Old Aug 18, 2003 | 07:05 PM
Bailhatch's Avatar
mine opens easily. It's loud at anything over 5 psi too. Can you push the piston in with your thumb? Maybe try to lube up the inside with some spray stuff. Make sure the vac/boost line is placed after the TB.
Old Aug 18, 2003 | 07:11 PM
Cee_mon's Avatar
Default Re: 1g bov question (Bailhatch)
mine you can hear clear at 5psi...during normal driving condidtions...no more than 3200rpm
Old Aug 18, 2003 | 08:16 PM
Pengo's Avatar
Default Re: 1g bov question (Cee_mon)
if i take mine close to 0 vac and get off the pedal i can hear it just whisper. anything in boost you can definitely hear clearly like a clean whoosh of air
Old Aug 22, 2003 | 10:50 AM
Default Re: 1g bov question (Pengo)
but since im running open dp. the chances of me hearing are hard right. when i boost i cant hear it, maybe my open dp is the cause, think thats it?
Old Aug 22, 2003 | 11:13 AM
psileepR's Avatar
New User
yes... the 1g bov uncirculated is more like a sneeze than anything... your open dp prolly drowns the sound out.
Old Aug 22, 2003 | 12:21 PM
ScottEK's Avatar
Default Re: 1g bov question (psileepR)
I had the exact same setup, without the downpipe on I couldn't hear the BOV. Once I connected the downpipe the BOV was VERY loud. Sounds great.
Old Aug 22, 2003 | 01:52 PM
Default Re: 1g bov question (beta13)
you think its was loud before? because if i connect my dp on to my cat its gonna be very weak because i cant afford my exhaust yet
ham
Sep 24, 2005 08:13 AM
Jayboy
May 12, 2005 10:57 PM
BlackB18CTeg
Oct 4, 2003 11:16 AM
DOHCarp
May 31, 2003 09:17 AM
boostedcoupe
Nov 21, 2002 10:24 AM
