my turbo set-up for my h22a
this is my set-up tell me some of the things that I will and wont need if I missed anything.
This is my turbo -set-up and motor buildup. here goes.
T3/T4
Je low compression 9:8:1 pistons
Darton sleeves
Eagle rods
550cc RC injectors
FJO Wideband O2
Aem or Hondata s100 or s200 plus boost option
street drag radials
Turbo guage
Turbo timer
MSD-BTm
Tial 35mm- 40mm wastegate
TurboXS Blow-off valve
Well tell me what you guys think?? for 12-15 psi?
I also have a act heavy dutty street/strip sprung hub disk with a quaife differential with billet fpr,and 255 venom fuel pump.
T3/T4
Darton sleeves
Eagle rods
550cc RC injectors
FJO Wideband O2
street drag radials
Turbo guage
Turbo timer
MSD-BTm
Re: my turbo set-up for my h22a (preluder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preluder »</TD></TR><TR><TD CLASS="quote">this is my set-up tell me some of the things that I will and wont need if I missed anything.
T3/T4
Darton sleeves
Eagle rods
550cc RC injectors
FJO Wideband O2
street drag radials
Turbo guage
Turbo timer
MSD-BTm
I also have a act heavy dutty street/strip sprung hub disk with a quaife differential with billet fpr,and 255 venom fuel pump.</TD></TR></TABLE>
Your going to need a manifold, iping, oil feed and return and intercooler
Your also going to need baring, gaskets, h2o and oil pumps, tbelt, etc etc.
That is just a start
T3/T4
Darton sleeves
Eagle rods
550cc RC injectors
FJO Wideband O2
street drag radials
Turbo guage
Turbo timer
MSD-BTm
Re: my turbo set-up for my h22a (DLB1994)
why 720cc and what kind of colder plugs do I need with gaskets should I just order the kit from importparts.com or do it myself?
Yeah, get 720's. Better than to have more than not enough. Plus if you want to turn up the boost past those levels, 550cc won't support it.
I live under a rock
Re: my turbo set-up for my h22a (badCRX)
If you are rebuilding the entire motor........ and with sleeves it sounds like you are you're going to need bearings- rod and main, a full gasket kit for the block as well as one for the head......i just ordered all that stuff today for my h23..... about 600$ from honda.......watch out boosting high on those eagle rods.......i've seen them break a few times on cars running 1bar+...... good luck!
might look into a higher flowing fuel rail, FPR, id go w/pauter rods(my preference), dartons seem like a good choice. (i went GE and am having some issues, but it could be OK if they take care of the issue)
but yea, ur gonna need a mani and piping.
AllMotorITR
11-30-2001 03:03 PM
