1976 Honda CVCC engine Turbo swap Project: To "B", or not to "B"?
#51
-Intl Steve Krew
Re: 1976 Honda CVCC engine Turbo swap Project: To "B", or not to "B"?
Essentially, yes. If my hazy memory serves me correctly, there aren’t many mods necessary for a ZC swap compared to a single cam. It was a common upgrade in a first gen, so I assume that a single cam will fit about the same given the mods that the 1200 guy did.
#53
Ok, I think I understand ya now.. He had a bit more carving up to do on the 1200 than you would on the 1500, yeah?
#54
If you can find a good Z6 and only Z6 swap and your target is up to 350whp ,
the YCP vitara / custom length rods 550$ combo blows the B swap out of the water power per money spent easy.
At THAT car i wouldnt go for anything over 350 whp anyway.
If it itches you to go for 400-450whp+ youll have to go B series.
The ZC is imo only for NA D series crazyness if you count your dollars...
#55
#56
You can hit huge numbers. Its the crazy good $/hp ratio that gets destroyed after 350whp on the D series making a the B a better choice.
#57
I look at what I've spent to this point now vs B builds spending the same amount and the B may be higher in numbers but again, it's not apples to apples. You won't, in most cases, have to replace internals on a B at such a low level, but certainly would be required for a D. HOWEVER... Now that seal has been broken, you can now take the D even further before really worrying about major spending. I'm pretty deep in myself but realize there's much more I could spend. However, 3 tuners I have spoken with already have all concurrently agreed, I should have ZERO difficulty hitting 400whp with my setup as is. Said I should keep it below 450 because pump gas, And bugging me relentlessly to tune it on E85. Lol!
#58
Well, I have made the choice to use a d16z6 engine and an S20 transmission, hopefully out of a 1995 Civic Del Sol (I prefer the GR in that tranny). As for boost, I will be keeping it rather low. My new power goals will be a more modest 200-250 WHP with the option to upgrade to the 300-350 range. The engine swap has to be put on hold until I can complete other aspects of the build. I will provide a link on my new thread back to this one and anyone interested can follow my progress elsewhere until I am ready to boost (just to keep my work in the correct section of the forum[s]). Thank you all so much. I have learned a lot and I am happy to have a set plan in place now.
