18g vs 15g
Old 09-22-2003, 01:40 PM
egchan's Avatar
Default 18g vs 15g
i have a fully built z6 i want to turbo. i've had my eye on the greddy kit because it's carb legal and cheap. but i want a bigger turbo. so i was thinking that since greddy makes the 18g and the 15g, the flanges should be the same, right? the only other option was the ad on top for needboost.com. they have a great deal on their t-20 and t-25 kits with ic, bov, and everything. but i showed it to my dsm buddy and he said if the t-20 is anything like the stock ones on some dsms, it would be shitty. so if the needboost turbo is at least as big or bigger than greddy's, i would probably get that. if not i'd like to know if any of you guys know if thst 18g would fit on greddys manifold for the z6. thanx
Old 09-22-2003, 02:35 PM
5thgencivic's Avatar
Default Re: 18g vs 15g (SlickCRX)
The 18g won't fit on the mani for the 15g. The 18 uses a T3 style flange I think.
Old 09-22-2003, 02:40 PM
p0gi's Avatar
Default Re: 18g vs 15g (5thgencivic)
no the 18g has a t25 flange , at least the greddy 18g does
Old 09-22-2003, 02:46 PM
What is this crap?
falcongsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thgencivic &raquo;</TD></TR><TR><TD CLASS="quote">The 18g won't fit on the mani for the 15g. The 18 uses a T3 style flange I think.</TD></TR></TABLE>
really? that doesnt make any sense
btw, 18g and 15g refer to the compressor side of the turbo, not the exhaust/turbine side.
the whole name for the greddy turbo for GSR is TD05H-18g. the "TD05H" part refers to the turbine side. i am pretty sure you can bolt a 18g compressor wheel and housing to a greddy turbo that came with a 15g compressor wheel.
i wish i could say for sure that they all have the same (t25) flange, but i forgot.
Old 09-22-2003, 02:49 PM
p0gi's Avatar
Default Re: 18g vs 15g (falconGSR)
what flange does the 15g have?
Old 09-22-2003, 04:35 PM
I don't know, hehe. I just used search and like 3 different people said the 15g and 18g use different flanges. Although somebody a long time ago told me the 18 would work on the sohc kit... Somebody confirm
The sohc kit comes with the TDO4H-15g
Dohc with the TDO5H-18G
So the TDO5H has to use a bigger flange right?
Old 09-22-2003, 06:16 PM
B18Flip's Avatar
OT: Whats size t-series turbo is an 18g equivalent too?
Old 09-22-2003, 06:23 PM
p0gi's Avatar
Default Re: 18g vs 15g (B18Flip)
its like a t-28
Old 09-22-2003, 06:37 PM
biassj's Avatar
Default Re: 18g vs 15g (p0gi)
Very close to a t3, probably the same. I use to have Greddy 18g, and no way it's a 15g style flange. The compressor looks like a 60-1 cause of the 4 inch inlet.
Old 09-22-2003, 06:54 PM
boostsohfast's Avatar
Default Re: 18g vs 15g (biassj)
I have personally seen the 15g on the greddy b-series manifold and it bolted right up.
Old 09-22-2003, 07:17 PM
p0gi's Avatar
Default Re: 18g vs 15g (boostsohfast)
the inlet is 3" and the flange is a t25 on an 18g
Old 09-22-2003, 07:18 PM
Happyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostsohfast &raquo;</TD></TR><TR><TD CLASS="quote">I have personally seen the 15g on the greddy b-series manifold and it bolted right up.</TD></TR></TABLE>
I've read in a few threads on here that the turbos are interchangeable with the manifolds. Call Greddy and ask...lol.
Old 09-23-2003, 05:08 AM
egchan's Avatar
so you think that the 18g would bolt up to the sohc manifold? i guess i'll call greddy and see if this can work. where do you guys think this size of a turbo would spool at on a sohc motor?
Old 09-23-2003, 05:47 AM
VTC_CiViC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by falconGSR &raquo;</TD></TR><TR><TD CLASS="quote">the whole name for the greddy turbo for GSR is TD05H-18g. the "TD05H" part refers to the turbine side. i am pretty sure you can bolt a 18g compressor wheel and housing to a greddy turbo that came with a 15g compressor wheel.
Nope. The DOHC kit uses a TD05 turbine, the SOHC kit uses a TD04 turbine, 18G compressor won't bolt up.
Old 09-23-2003, 01:11 PM
egchan's Avatar
Default Re: 18g vs 15g (VTC_CiViC)
well i just talked to greddy. there is no upgraded turbo for the sohc kit, and the 18g won't bolt up to the sohc manifold nor the compressor wheel. so either i get stuck with this turbo wanting more, or i can find a bigger setup cheap like the greddy. any ideas guys?
Old 09-23-2003, 02:38 PM
Jockobo's Avatar
u can always get the turbo ported n stuffed with bigger wheels. i seen that somewhere...not sure though
Old 10-04-2003, 12:02 PM
mugensport9's Avatar
Default Re: 18g vs 15g (Jockobo)
what about the 16g?
Old 10-04-2003, 12:30 PM
Happyman's Avatar
Default Re: 18g vs 15g (mugensport9)
I'm almost possitive the SOHC manifold is a standard t3 flange.
Old 10-04-2003, 01:16 PM
Default Re: 18g vs 15g (eh6turbo)
could you just swap the manifold and get an sohc t3 mani with a t3 turbo and keep the rest of the set up? would that work? because its like 500 for a sohc t3 and matching mani.
that sounds like it could be a quick upgrade
would that work or no?
Old 10-04-2003, 01:19 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugensport9 &raquo;</TD></TR><TR><TD CLASS="quote">could you just swap the manifold and get an sohc t3 mani with a t3 turbo and keep the rest of the set up? would that work? because its like 500 for a sohc t3 and matching mani.
would that work or no?</TD></TR></TABLE>
something such as this?
http://cgi.ebay.com/ebaymotors...33742
would that work?
Old 10-04-2003, 01:51 PM
Happyman's Avatar
I guess it would work. But that turbo is way too big for a sohc. And I dunno what manifold that is but I bet it'll crack. Those Ebay manifolds are weak. Maybe with some extra bracing? I dunno.
Old 10-04-2003, 02:36 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eh6turbo &raquo;</TD></TR><TR><TD CLASS="quote">I guess it would work. But that turbo is way too big for a sohc. And I dunno what manifold that is but I bet it'll crack. Those Ebay manifolds are weak. Maybe with some extra bracing? I dunno.
so what would be a good upgrade mani/turbo for the sohc?
MR2bl326
01-25-2007 02:37 PM
97grnrs
12-03-2006 07:22 PM
Royal_C!ty
07-06-2006 05:08 PM
Square
10-12-2004 12:08 PM
pelotudo
11-30-2002 05:50 AM
Quick Reply: 18g vs 15g
