Greddy Manifold Compatible with TD04 Clipse turbo ? ...
Long Story Short ...
I need to replace my 15g turbo , I found a DSM TD04 turbo locally (pictured below) before i go wasting my time and gas i'm just wondering if one of you greddy guys or any turbo guy in general knows
Question :will the pictured DSM TD04 turbo mount to a d-series greddy manifold ? if so will i be lucky enough to use the greddy downpipe as well ?
Quick Respone would defintely be helpful trying to pick up today !
Thanks in advance ...
- Justin
- Justin
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Re: Greddy Manifold Compatible with TD04 Clipse turbo ? ... (eg8kid)
Nope.
Greddy manifolds use a NISSAN T25 flange, NOT a DSM one.
Re: Greddy Manifold Compatible with TD04 Clipse turbo ? ... (boostincoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe »</TD></TR><TR><TD CLASS="quote">Nope.
Greddy manifolds use a NISSAN T25 flange, NOT a DSM one. </TD></TR></TABLE>
so the t25 off of a 300zx would fit than correct ? ... only reason i ask is everyone says only the jdm turbos off the silvias, etc. work ...
i stumbled upon 2 t25's on a 300zx but didn't know if they fit or not, you know if there compatible with the downpipe by chance ? ...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg8kid »</TD></TR><TR><TD CLASS="quote">
i stumbled upon 2 t25's on a 300zx but didn't know if they fit or not, you know if there compatible with the downpipe by chance ? ... </TD></TR></TABLE>
Yes, any Nissan T25 flange fits. On my old Greddy kit, I replaced the worn out turbine outlet gasket with a Nissan 300ZX OEM gasket.
I just put a gt28r that was setup for a nissan on my greddy manifold. I did have to clock the turbo and buy an adapter plate and a different wastegate though to make it fit. I also had to shave the block a little. You can find some used gt28r's out there on nissan forums.
Re: (1epmugenlude)
I believe it will. I think the dimensions of it are very similiar to the gt28r, just different internal wheels and such. You will most likely have to shave the block where theres a bolt hole on the d16.
