18g is going crazy
Old Jul 6, 2004 | 05:53 PM
whackassfawker's Avatar
Default 18g is going crazy
I'm running 14 psi on my teg using an 18g. For the past 3 months it has held no problem. Just in the past few days it began overboosting. I'm using the same mbc, and everything is the same, so why all of a sudden would this happen. I checked all connections and they are ok.
Old Jul 7, 2004 | 08:08 AM
bump
Old Jul 7, 2004 | 08:12 AM
Nihilation's Avatar
Cracked Vacuum line somewhere? Does it overboost all the time?
Old Jul 7, 2004 | 08:13 AM
If I use the same line and splice it straight through without the mbc the boost comes on fine.
Old Jul 7, 2004 | 08:15 AM
Andrew 825SM's Avatar
Default Re: (whackassfawker)
It's ballastic man!
Old Jul 7, 2004 | 08:16 AM
b20turbojason's Avatar
Default Re: 18g is going crazy (whackassfawker)
sounds like your mbc is craping out.
Old Jul 7, 2004 | 08:18 AM
I have a turbosmart mbc and it's always been right on. What parts could fail?
Old Jul 7, 2004 | 10:06 AM
Turbo E's Avatar
maybe the internal spring perhaps
remove the MBC and see if you get consistant (altho less) boost pressure.
Old Jul 7, 2004 | 12:09 PM
Default Re: (Turbo E 604)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E 604 &raquo;</TD></TR><TR><TD CLASS="quote">maybe the internal spring perhaps
remove the MBC and see if you get consistant (altho less) boost pressure.</TD></TR></TABLE>
The mbc I'm using is the turbosmart gated valve and it does not have a spring. Can the actuator on the turbo get lazy over time?
Old Jul 7, 2004 | 01:42 PM
Turbo E's Avatar
not sure, but i'd remove the MBC just the same to avoid blowing your motor
Old Jul 7, 2004 | 02:32 PM
M.A.R.C.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E 604 &raquo;</TD></TR><TR><TD CLASS="quote">not sure, but i'd remove the MBC just the same to avoid blowing your motor</TD></TR></TABLE>
try that first.
Old Jul 9, 2004 | 04:03 PM
powerls's Avatar
try a different vacuum source and make sure to recalibrate your mbc
Makdaddynuge
Jun 4, 2006 03:46 PM
turbo95eg6
Jun 12, 2005 07:46 PM
5l-eater
Oct 20, 2004 03:26 PM
See Are X
Oct 1, 2004 09:34 PM
quickergixxer
May 13, 2004 05:55 PM
