injectors?????
Old Sep 2, 2004 | 04:00 PM
jdmtim's Avatar
Default injectors?????
I got a DA series teg I wanna buy larger injectors but I'm not sure if I need peak and hold or saturated ones. I got obd0 ecu, I dont want to order the wrong thing. Also here soon I'm going to go obd1 for hondata will the same injectors work for it??
Old Sep 2, 2004 | 05:52 PM
m00tjam's Avatar
Default Re: injectors????? (jdmtim)
im pretty sure you have peak and hold type injectors
Old Sep 9, 2004 | 01:49 AM
wicked2night's Avatar
How do you figure out what kind of injectors do you need?Peak and hold or the saturated ones?
What would you need for a b16 obd2 swaped civic?Looking for some 550's but i don't kno wich are the right ones?
Old Sep 9, 2004 | 07:30 AM
Rod.'s Avatar
you can use peak and hold w/ obd1 hondata. Actually probably be better if you did if you want big injectors
Old Sep 10, 2004 | 02:25 AM
Default Re: injectors????? (redturbocivic)
"If you want big injectors"??? What do you consider big?
So peak and hold can't be used with obd2?
Are one of this injector types better then the other?Can i pick wich injectors i want, before i decided what will i use for fuel managment (e-manage, AEM EMS,need something to work on myself)
jthrasher1
11
Dec 4, 2010 09:48 AM
EJ8 GSR-T
Apr 26, 2006 06:33 PM
caliprelude3087
Sep 2, 2004 12:54 PM
angela_itr
Jul 1, 2004 08:58 AM
FOrSfEd
May 15, 2002 08:08 AM
