14b turbo differences
Old Mar 27, 2004 | 07:01 AM
ironcheftony's Avatar
Default 14b turbo differences
i need to know the differences in these 2 turbos, i know the are both tdo5h and from a 1stgen eclipse, with same housing and all but then compressor side fins are different,
does it have any thing to do with spool and etc, which 1 is better
same housing, diff fins
diff numbers
hass a bigger inlet with beveled edge, dual fin design
smaller inlet with straight edge, single fin design
exhuast side, middle cartridge is a little different
can anyone tell me some good information on these, thanks
Old Mar 27, 2004 | 01:16 PM
Default Re: 14b turbo differences (ironcheftony)
beep
Old Mar 27, 2004 | 02:03 PM
kpt4321's Avatar
The one on the right with the two different heights of compressor fins is not a 14b. It is some 16g variant, either a "big" or small 16g. it did not come on an Eclipse.
Old Mar 27, 2004 | 02:29 PM
SiRkid's Avatar
go with the 16g!
Old Mar 27, 2004 | 02:52 PM
5STAR3's Avatar
Default Re: 14b turbo differences (SiRkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRkid &raquo;</TD></TR><TR><TD CLASS="quote">go with the 16g!</TD></TR></TABLE>
for sure
Old Mar 27, 2004 | 03:51 PM
are yall guys sure its a 16g, because i pulled it off a eclipse, im pretty sure it was an eclipse, it was at the junk yard, but maybe the previous owner upgraded the turbo, does anyone know when the 16g hits full boost at 10psi, bkuz mine hits at 4500ish bkuz of the chipped fins, can anyone verify this for me, or show me some other 16g turbo pictures, thanks
Old Mar 27, 2004 | 03:59 PM
joey1320's Avatar
Default Re: (ironcheftony)
the 16g is a stright replacement for the 14b so most def. the previous owner upgraded. Go with the 16g as the other guys said, it's a much better flowing turbo!
Old Mar 27, 2004 | 04:26 PM
the turbo on the right is mine, i been using is i was just going to get a better one bkuz the fins are chipped and that might have affected my turbo spool but i dont know, can anyone tell me that, as well as some leaking but it works, it pulls hard ill tell you that tho
Old Mar 28, 2004 | 08:30 AM
answers....
Old Mar 28, 2004 | 01:12 PM
Civiclx's Avatar
looks like the difference is just the compressor wheel, same td housing just 16g vs 14b
gldndrgn14
May 8, 2007 11:17 PM
stockredej1
Apr 8, 2007 10:56 AM
Rob!
Jul 25, 2004 11:12 PM
whagkangmakulet
Nov 13, 2001 05:21 AM
