Is 12 sec possible with my setup???
Old Apr 16, 2006 | 10:55 PM
juniestyle's Avatar
Default Is 12 sec possible with my setup???
99 civic si:
Stock Gsr motor
act stage 1 clutch
lightened flywheel
aem fuel rail
aem fuel pressure reg
aem adj cam gears
drag turbo kit t3to4e
dsm 550cc injectors
vafc 2
Wanting to know if i can hit 12 sec in 1/4 mile with 7 lbs of boost, if i cant what what numbers im a looking at and hp?
Old Apr 17, 2006 | 05:02 AM
Soccerking3000's Avatar
Default Re: Is 12 sec possible with my setup??? (juniestyle)
sure y not... also just go to the dyno get it tuned know how much power it actually has then go take it to the drag strip and actually run, viola no more specualtion and wondering...
Old Apr 17, 2006 | 10:11 AM
juniestyle's Avatar
Default Re: Is 12 sec possible with my setup??? (Soccerking3000)
true...but just wanted to see if anyone here with this setup hit 12 sec on a quarter mile.
Old Apr 17, 2006 | 11:05 AM
ccivic's Avatar
Going to be difficult with only 7psi on that turbo in such a heavy car. Get rid of the VAFC and go with Hondata, Crome, or something of the sort. Have it properly tuned with a wideband by a knowledgable tuner.
Old Apr 17, 2006 | 11:59 AM
zex_cool's Avatar
Default Re: Is 12 sec possible with my setup??? (ccivic)
si w/ gsr ??? why ?
to answer your question NO ! ! !
Old Apr 17, 2006 | 01:49 PM
allmotor89hf's Avatar
heavier duty clutch
lsd
ditch the vafc for hondata, chrome or uberdata...something other than a vafc
shed some wieght if possible
slicks or dr's
up the boost
dyno tune it.
i could be wrong but i would say youd need something around 280+whp to get consistant 12 second passes. on 7lbs your around...what...240ish? if this was a lighter car it would be different.
brad98_teg's Avatar
not with that turbo on 7lbs
Old Apr 17, 2006 | 03:21 PM
Mugencrxsir1's Avatar
Default Re: (brad98_teg)
Try 15psi, that will get you close to the 12's, definately 12's in ef! If you are a good driver, 7psi on a stock b16 will net you around mid-upper 13's.
Old Apr 17, 2006 | 04:39 PM
zex_cool's Avatar
hahaha
ok how about me
EK w/d16z6 y8 IM w/dsm 450 injectors
no interior
93 octain
205/40/16 street tires
std mani
14b w/ 10psi
2.5'' DP,catless exhoust
tuned w/ crome
can i get it into the 10s ???
lol
Old Apr 18, 2006 | 04:30 AM
Jay_Sensing's Avatar
You just need a bit more boost and you should be in there. I hit a 12.67 with a full weight SI plus a sub and ginormous amp on 12 lbs. Granted my turbo is a bit better but you have more displacement and higher compression.
The only way to really find out though is bolt on a a set of slicks and head to the track. Driver skill will play a big role.
Old Apr 18, 2006 | 06:56 AM
Schister66's Avatar
Man U FTW
even if you up the boost and get a different tuning system you're not going to hit the 12's......your clutch is going to slip and kill all the power you would have gained....upgrade that and maybe get LSD while its apart and you have a good set up
Old Apr 18, 2006 | 09:11 AM
jfoster's Avatar
Default Re: (Schister66)
Oh, oh, my turn!
'95 Integra LS full weight with AC/PS/ABS etc
walbro 255 intank
AEM FPR
RC 550s
Magnecore wires
NGK BKR7Es
BLOX mani
38mm TiAL 10psi spring
Precision SC34
2.5" DP flares to 3" right after AC
open dump
3" exhaust
K&N filter
2.5" IC pipes
Spearco FMIC
1g dsm bov
UD V1.7 AFR dialed, timing untouched
93 octane
Kumho Ecsta Supra 712s
I realized theres no real way to know, just curious about opinions/estimates etc
CTR_B
Jun 13, 2008 06:36 PM
Yambor
Apr 29, 2005 09:39 AM
Luchini
Apr 16, 2004 03:49 PM
NMElude97
Jan 7, 2004 09:41 AM
