100 octane sohc turbo
Old Mar 28, 2005 | 06:51 AM
Tapen00n's Avatar
Default 100 octane sohc turbo
with 100 octance gas would it be safter to pump up the boost on my stock internal d?
Old Mar 28, 2005 | 07:16 AM
Johnyquest's Avatar
Default Re: 100 octane sohc turbo (Tapen00n)
Safer than with 93, sure.
Matt
Old Mar 28, 2005 | 08:24 AM
flip1199's Avatar
Default Re: 100 octane sohc turbo (Johnyquest)
how many lbs are u running now? and what do u plan to up it to?
Old Mar 29, 2005 | 08:18 PM
Tapen00n's Avatar
Default Re: 100 octane sohc turbo (flip1199)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flip1199 &raquo;</TD></TR><TR><TD CLASS="quote">how many lbs are u running now? and what do u plan to up it to?</TD></TR></TABLE>
with 93 i was gunna run 10psi, what could i run with the 100
Old Mar 29, 2005 | 08:28 PM
dr_latino999's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tapen00n &raquo;</TD></TR><TR><TD CLASS="quote">with 93 i was gunna run 10psi, what could i run with the 100</TD></TR></TABLE> Relative to your internals and your tuning.
Old Mar 29, 2005 | 09:25 PM
Evo-man@20psi's Avatar
It wont hurt anything
Old Mar 29, 2005 | 09:52 PM
BME1986's Avatar
Default Re: 100 octane sohc turbo (Blue00vtecsi)
Well to run more than 10, you will need a 3 bar. What type of ems are you using? Do u have stock internals?
Old Mar 30, 2005 | 05:55 PM
Tapen00n's Avatar
Default Re: 100 octane sohc turbo (BME1986)
cp std bore low comp. pistons and stock rods
Old Mar 30, 2005 | 05:56 PM
nonvtecD's Avatar
stock rods? What turbo is this on?
Old Mar 30, 2005 | 06:24 PM
turboEGhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tapen00n &raquo;</TD></TR><TR><TD CLASS="quote">cp std bore low comp. pistons and stock rods</TD></TR></TABLE>
Why in the sweet name of jesus would you tear the motor down, but skimp out 300 bucks for a set of rods that are 10 times stronger than your stockers?
Old Mar 30, 2005 | 06:35 PM
SOHCmaster's Avatar
I been running 10psi for 2 years and still running 10psi now with stock d internals. I dont know why people are so scared of 10psi.. 8-10psi is solid for 93
Old Mar 30, 2005 | 06:59 PM
Default Re: (PK SPEED)
It's not "being scared" of running that much boost, it's why the heck would you go to the extent of completely tearing the motor down and rebuilding it, but not saving up for an extra week and getting some decent rods to replace the stockers. That's like recruiting Maurice Green, Michael Johnson, and Tim Montgomery for a 4 x 100M relay team, then throwing George Foreman in there to run anchor, and tell em to have at er. If you're gonna go as far as to build your motor, why not remove the one main weak link from it.
Old Mar 30, 2005 | 08:08 PM
Drew Peacock's Avatar
Default Re: (turboEGhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboEGhatch &raquo;</TD></TR><TR><TD CLASS="quote">It's not "being scared" of running that much boost, it's why the heck would you go to the extent of completely tearing the motor down and rebuilding it, but not saving up for an extra week and getting some decent rods to replace the stockers. That's like recruiting Maurice Green, Michael Johnson, and Tim Montgomery for a 4 x 100M relay team, then throwing George Foreman in there to run anchor, and tell em to have at er. If you're gonna go as far as to build your motor, why not remove the one main weak link from it.</TD></TR></TABLE> LOL yeah the rods are still the weakest link so upto about 250whp is all you would really want to go unless you want to break your rods. You haven't listed your compression ratio or turbo size... I ran 16psi on similar fuel with standard comp. Its hp or detonation that will break the rods though .
socallmechris
10
Jan 12, 2008 04:42 PM
meangreenEG
Aug 10, 2007 04:47 PM
steve96accord
Jun 18, 2006 03:06 PM
dabig1
Nov 28, 2004 05:05 PM
HYREV2NR
19
Feb 10, 2004 06:02 PM
