1.8l turbo?
I want to know which turbo would be ideal for a street setup on itr stock block with cometic head gasket .057 to lower the compression plan to run the most 12psi
sc34 a/r 63 trim 69
sc61 same a/r and trim
should i go with a smaller a/r ?
will the sc61 be overkill and lag to much or will it have decent low end b/c the compression wont be super low
looking for 300+ hp and want boost till last until 9000 rpm will be running hondata s200b and 255 in thank and rc 650cc saturated
sc34 a/r 63 trim 69
