HI compression and A big 'ol turbo....
Old Jun 1, 2002 | 10:53 AM
*Boostwerks*'s Avatar
Default HI compression and A big 'ol turbo....
How effective is Hi compression at spooling up a turbo, compared to low compression?
For instance, A 10:1 CR with a T3/T04E (Not giving exact specs but assume it's pretty big) VS.... a 8.5:1 CR with the same turbo.
How many RPM's do you think the HI CR will be different?
Thanks for any info!
Old Jun 1, 2002 | 11:08 AM
93LSivic's Avatar
Default Re: HI compression and A big 'ol turbo.... (Bryson)
You should really be asking yourself if the turbo is good to use with the high compression.
Flow maps for the turbo will tell you if you need to run a high boost or low boost to get it into the right efficiency range.
Another words, you want to run a conservative amounts of boost on a 60-1 turbo--anything under about 15 psi. Good for a higher compression motor on low boost and great tuning.
Now for my application. A t3/t4e that doesnt really wake up to 10-11 psi and can be run up to 25 psi. Ofcourse with lower compression, it is easier to boost at those levels with the ability to go higher with race gas.
So, you should actually be matching the turbo to your motor/compression to get the best results of the turbo from the flowchart.
Old Jun 1, 2002 | 11:30 AM
Default Re: HI compression and A big 'ol turbo.... (93LSivic)
True.
BUT...That really didn't answer my question.
Is there truly a measurable difference in spool time between the two compressions?
That's all I'm asking.
Old Jun 1, 2002 | 11:33 AM
2K_TEG's Avatar
YES
(this is here because of the damn half captial letters rule)
jinxproof99's Avatar
New User
i would rather have larger displacement than higher compression. spools turbos quicker, better torque, and safer then higher compression(easier to tune). just my opinion.
Old Jun 1, 2002 | 11:36 AM
dmotoguy's Avatar
Default Re: HI compression and A big 'ol turbo.... (jinxproof99)
2K_TEG
i have your little icon of the modena's crashing on my desktop... i also have the video it almost made me cry
sorry for being off topic...
as for the difference in spool time, it might make 200-400 rpm difference, need more details to answer the question correctly
Old Jun 1, 2002 | 11:37 AM
I want to be a little different.
Old Jun 1, 2002 | 11:39 AM
Default Re: HI compression and A big 'ol turbo.... (dmotoguy)
Cool. Good enough for me.
Thanks!
Old Jun 1, 2002 | 01:24 PM
2K_TEG's Avatar
2K_TEG
well, I am way off topic too, can you send me that video? I just have the picture. If you oculd I would appreciate it. westkyle@ameritech.net
henchie
Mar 28, 2016 07:20 AM
cmasonrun
Oct 6, 2007 11:56 AM
slowcrx954
Nov 23, 2006 07:49 AM
Charlie Moua
Nov 8, 2002 05:08 AM
Feuerraeder
Feb 23, 2002 09:11 PM
