02 civic system too lean
Old Jul 22, 2008 | 05:25 PM
bigmikey7351's Avatar
Default 02 civic system too lean
looking to fix a problem before the turbo setup gets added. CEL "system too lean (bank 1 sensor 1)". Also have a wideband on there and its runnin lean on startup and full throttle, when it should be rich I believe. Replaced map sensor so far haven;t found a vaccuum leak, gonna do a fuel pressure test the next time i can work on it. Any other suggestions or help would be greatly appreciated.
Old Jul 25, 2008 | 06:20 AM
CivicPride97's Avatar
Default Re: 02 civic system too lean (bigmikey7351)
bump
Old Jul 25, 2008 | 08:46 AM
EASY101's Avatar
* B A N N E D *
what kinda setup do you have? on a 02 civic, the best thing is to convert it to a return style system. use a walbro 255, and a aeromotive fpr and upgrade injectors of course. and what ems?
and you're gonna need to modify your stock rail or get a new one fabricated in order to make it a return style.
Modified by EASY101 at 11:54 AM 7/25/2008
tech23
10
Feb 11, 2010 07:40 AM
99GreenEX
29
Jul 2, 2008 10:26 AM
wiZCo
Sep 8, 2006 01:03 PM
Witty
May 29, 2003 06:05 AM
shadowdawn
Sep 24, 2002 10:24 PM
