Threw Code 45 in 96 civic
Old May 27, 2003 | 06:32 AM
Witty's Avatar
Default Threw Code 45 in 96 civic
Code: 45
96-98 Civic
97-98 CRV
96-98 Prelude
94+ Integra
System Too Lean or Too Rich malfunction in the fuel monitoring systems
Anyone know what sensor this could be?
Old May 27, 2003 | 06:50 AM
577HondaPrelude's Avatar
Default Re: Threw Code 45 in 96 civic (Witty)
primary O2 sensor. Or it's working and the car is really running too rich or too lean. In that case could be: fuel pressure regulator, fuel filter, fuel injectors, MAP sensor or vacuum leak.
Old May 27, 2003 | 07:22 AM
Witty's Avatar
Default Re: Threw Code 45 in 96 civic (57STS)
Honda mechanic said it's a sensor and the part alone costs $400.
Modified by Witty at 10:03 PM 5/27/2003
Modified by Witty at 10:18 PM 5/27/2003
Old May 27, 2003 | 07:41 AM
it's the primary O2 sensor then, that's the one before your cat, on the header side. $400 is way too much! more like $70 for a new one. Unless you have one of those ultra lean buring civics (not sure what year that was) then it's more like $200.
Old May 27, 2003 | 09:45 AM
Witty's Avatar
How easy is it to change this sensor?
Old May 27, 2003 | 09:46 AM
Nextelbuddy's Avatar
expensive from honda i can tell u that. check your wiring first and see if its a shirt in the system. O2 sensors are expensive
Old May 27, 2003 | 01:01 PM
Witty's Avatar
Default Re: Threw Code 45 in 96 civic (nextelbuddy)
Car has major hesitation and is running rich. Car also has some type of hissing sound but nobody can find the noise. Could this mean it is not the sensor? Mechanic said he thought there was a vacuum leak but couldn't find it.
Old May 27, 2003 | 06:32 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Witty &raquo;</TD></TR><TR><TD CLASS="quote">Car has major hesitation and is running rich. Car also has some type of hissing sound but nobody can find the noise. Could this mean it is not the sensor? Mechanic said he thought there was a vacuum leak but couldn't find it.
If the car has less than 150,000 miles on it, take it to a dealer to get it checked out and repared for free. (Under the emmision extension warranty.)
Old May 28, 2003 | 06:15 AM
Witty's Avatar
Default Re: Threw Code 45 in 96 civic (Chiovnidca)
Where can I find info on that?
Old May 28, 2003 | 01:34 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Witty &raquo;</TD></TR><TR><TD CLASS="quote">Where can I find info on that?</TD></TR></TABLE>
Just go to a dealer with the CEL on.
Old May 29, 2003 | 06:05 AM
Witty's Avatar
I did, they tried to charge me $600.
avrfan
Aug 25, 2014 01:59 AM
Hanmin
Sep 20, 2008 10:37 AM
acurakid6786
Feb 10, 2005 10:00 AM
Btothe3rdDegree
10
Jun 22, 2003 04:51 PM
SoPoCivic93
Sep 26, 2002 02:20 PM
