A 00 Coupe SI in the 11's
Old Aug 13, 2002 | 08:43 AM
revhardsi's Avatar
Default A 00 Coupe SI in the 11's
Anyone here know what it takes to get a coupe with full interior down the 1320 in 11.5 to 11.0 seconds?? Besides allot of horsepower. If any guys on here run a particular suspension setup and/or motor turbo setup that have done this let me know, I've been looking at the SFP civic SI and they ran a 11.40 with it being a daily driven street car also. Can a drag gen 3 turbo kit at 15-20 psi get me in the ballpark, or do I need a bigger turbo??
car as it sits consists of...
1.8l sleeved block
race port head
Stock SI trans with Quaife and ACT clutch
kyb shocks and skunk 2 coilovers
z10 radius arm kit
breddy type 24 intercooler with pipes and tial BOV
planning on a revhard manifold with a t3/t4 hybrid at 20 psi with a tial wastegate
Old Aug 13, 2002 | 08:54 AM
93LSivic's Avatar
Default Re: A 00 Coupe SI in the 11's (revhardsi)
Why not just call SFP and say I want a replica of your Si, here are my credit card numbers.
Old Aug 13, 2002 | 09:09 AM
SiRkid's Avatar
do probably have pistons and rods with that sleeved block..you probably are gonna wanna bump your turbo size to a t3/60-1
Old Aug 13, 2002 | 09:24 AM
revhardsi's Avatar
Default Re: A 00 Coupe SI in the 11's (SiRkid)
thanks, I was really confused on what turbo I should run.
Old Aug 13, 2002 | 09:45 AM
jinxproof99's Avatar
New User
you'll want a t4, 60-1 and engine management. around 450 hsp to the wheels will net you mid to low 11's. depends on your weight(driver, ac, stereo, etc..) a medium sized t3/4 and approx 350 hsp will net you high 11's. 24.5" or 25" slicks required.
Old Aug 13, 2002 | 09:50 AM
TurboR's Avatar
New User
Default Re: A 00 Coupe SI in the 11's (jinxproof99)
the motor in the SI is a 2.0 but the car is sweet.. B16 stroked to a 2.0..
Old Aug 13, 2002 | 11:31 AM
Boostfed's Avatar
New User
I've hit numerous 11.90's in my Si. Blowing IC pipes, missing shifts and short shifting. Excuses excuses, I've hit the 11.90@106mph and 119mph and 120mph. I plan on low 11's high 10's with my new set up. Old set p was a DRAG 3 kit with 21psi. :D
Old Aug 13, 2002 | 12:23 PM
Boostfed's Avatar
New User
Default Re: A 00 Coupe SI in the 11's (4rcefed)
Also I have the simplest of suspension set ups, stock shocks with Integra 500lb/in front coilovers and Integra 400 lb/in rears. Rear jacked up(raked) and 24.5x7x13 MT slicks( I know need 8 or 9 inch wides) on Lensos.
Old Aug 13, 2002 | 02:38 PM
teamrocket si's Avatar
4rcefed, what block do you have? Is it sleeved?
Old Aug 13, 2002 | 02:54 PM
DLB1994's Avatar
Default Re: A 00 Coupe SI in the 11's (teamrocket si)
i think his block was not sleeved when he ran that # but he cracked a sleeve and he is re-sleeving now
Old Aug 13, 2002 | 03:00 PM
Boostfed's Avatar
New User
Default Re: A 00 Coupe SI in the 11's (DLB1994)
DLB is correct at the time it was stock sleeves open deck 81.5mm Endyn 9.3:1 pistons and Eagle rods. I now have a Golden Eagle Sleeved Block thanks to gsr*lude 84.5mm sleeved block, balanced bottom end(well was in balance) upgraded valvetrain ITR w/Portflow inners, Crower Ti Retainers, Mild p&p, JG/Edelbrock IM, T3/60-1 Turbo thanks to my sponsor(sorry John) , Maximum Performance Equal Length tubular manifold, MSD 72#(750cc) injectors, etc etc. Kind of the same it seems as everyone else now. Oh #3 Cylinder wall and sleeve cracked at the track, 21psi with an extra turn of the HKS manual boost controller. First gear second gear WHITE SMOKE BOOM!
itsjdm
May 26, 2009 10:47 PM
positiveforce63
14
Sep 11, 2007 06:01 PM
steve00si
Sep 28, 2006 09:33 AM
jdm4show
May 20, 2004 10:50 AM
ANTI-REDLINE
Jul 22, 2002 08:54 PM
