Installing rc injectors.
Old Aug 13, 2002 | 12:48 PM
shadowdawn's Avatar
Default Installing rc injectors.
Going to be getting my rc 440's with clips in. Now the clips will allow me to NOT have to dremel or mod the stock clips right? Also I keep reading that the o-rings supplied by rc won't work at all with fitting them..... will I need to get a different size o-ring other than stock or the rc's? Just wanna know what to expect when trying to put the injectors in and any problems teg people ran into with larger injectors like these and any helpfull experience you guys could share...
Old Aug 13, 2002 | 12:59 PM
DragII's Avatar
25 Year Member
Default Re: Installing rc injectors. (shadowdawn)
the RC 440s, clips, and o rings plugged right into my B16 without any issue. Direct replacement
Old Aug 13, 2002 | 03:02 PM
h0mesk1let's Avatar
I struggled putting in my RC injectors along with a few other members. I didnt have directions with mine, but found out that the injectors are suppose to push against the rubber bushing and not go in it. This is to prevent boost from leaking out.
Old Aug 13, 2002 | 03:03 PM
Trigun's Avatar
Default Re: Installing rc injectors. (EGb18cT)
yes the injectors according to RC should sit on the rubber grommets, not pushed into them. i installed mine the way RC suggested and i have had no problems at all
ihavenocar
Sep 16, 2008 10:42 PM
b20turboic
Aug 27, 2003 09:16 AM
