**Does Painting an Intercooler Black, Decrease Performance??
Old Aug 3, 2003 | 12:56 PM
  #26
LiLOtaku's Avatar
Default Re: **Does Painting an Intercooler Black, Decrease Performance?? (spock_rocker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spock_rocker &raquo;</TD></TR><TR><TD CLASS="quote">i'm painting mine!! when i get it
&lt;adam sandler&gt;WOOOPITY DOOOOO!&lt;/adam sandler&gt; ..................
Old Aug 3, 2003 | 02:05 PM
  #27
PreIudeSI's Avatar
From: California ... Beauuutiful, so cal, pwnited States
Default Re: **Does Painting an Intercooler Black, Decrease Performance?? (LiLOtaku)
the performance difference is negligible. It might decrease the effeciency in theory but in actuality, you'll only be running around .5 degrees more. My brother's teg was turbo'd with a flat black intercooler earlier in the summer in arizona and it worked just fine. Just hit it with a few light coats and don't clog the fins because that's what's doing to cooling, not the face of the intercooler.
Old Aug 3, 2003 | 02:08 PM
  #28
myprojectb13's Avatar
Default Re: (lazerus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazerus &raquo;</TD></TR><TR><TD CLASS="quote">if someone can create a coating that has better heat conductive properties than aluminum, then it would be productive to coat it, since it can take heat from the aluminum, and give it to the air more efficiently.
i belive there is a company that can do this though.
It would probably be a coating with a rough finish, to increase surface area, too.</TD></TR></TABLE>
Swain Tech has a heat radiating coating, http://www.swaintech.com/price.html. Its called BBE.
Old Aug 3, 2003 | 05:33 PM
  #29
stickshift's Avatar
Default Re: **Does Painting an Intercooler Black, Decrease Performance?? (russian_racer)
make sure you use a good metal paint or it could come off to easy. like in the rain on the high way or something like that. it will just wear off. good paint.
Old Aug 4, 2003 | 04:31 PM
  #30
pip9's Avatar
I might be painting mine while its down for engine work. There's a company online that sells a black radiator paint which should work perfect for anyone that wants to do this. http://www.eastwoodco.com/
97grnrs
Aug 2, 2007 06:28 PM
hialeahzbg
Apr 30, 2007 10:43 PM
I got a honda
Oct 20, 2004 07:31 PM
2muchPSI
Oct 3, 2003 10:45 PM
T3T495GSR
Jan 22, 2003 02:46 PM
