Factory rev-limiter. . . . . ?
Old Mar 17, 2002 | 10:28 PM
WykidEH's Avatar
Default Factory rev-limiter. . . . . ?
Is that true that the factory rev limiter is fuel-cut or is it spark-cut?
Old Mar 17, 2002 | 10:31 PM
Dee's Avatar
Dee
Default Re: Factory rev-limiter. . . . . ? (WykidEG6)
fuel cut....
Old Mar 17, 2002 | 10:33 PM
WykidEH's Avatar
Default Re: Factory rev-limiter. . . . . ? (drealgsr)
fuel cut....
Then, if you have a Turbo. If you bounce the limiter, you might have a chance running lean and blowing-up your engine?
Old Mar 17, 2002 | 10:58 PM
BLKCRX's Avatar
ithink we have had this debet before.. i think as long as the injectors r closed of 100% it should't cause a problem...
remember hondata launch control rev limit and what not cuts the fuel.. and nobody ever complains. me finks its all fine.... bc the injectors close 100%
Regards James
Old Mar 18, 2002 | 01:02 AM
Dee's Avatar
Dee
Default Re: Factory rev-limiter. . . . . ? (BLKCRX)
As long as you don't try to ride on top of the limiter for entended periods you will be ok!
hondacummins
Engine Management and Tuning
12
Jul 20, 2014 08:14 PM
honkey2fly
Jul 2, 2004 04:33 PM
htludernewbie
Aug 25, 2002 03:06 AM
Black R
Jul 25, 2001 12:46 PM
AdamITR
Jul 7, 2001 06:35 AM
