Question about setting timing with s300.
Old Feb 17, 2009 | 12:50 AM
TwoKSiR's Avatar
Default Question about setting timing with s300.
Ok so I was going to set the timing on my civic that's running s300. I used the set timing feature which sets to 16 degrees BTDC. Ok not the timing light I have has a **** on it to adjust the light. Do I turn that to 16 also or leave that on 0? I have never used a light that has the ****. Thanks.
Old Feb 17, 2009 | 03:13 AM
pb16b's Avatar
Default Re: Question about setting timing with s300.
if you're timed at 16BTDC and set the **** to 0, it should read 16BTDC (red mark). if you set the **** to 16, it should read TDC (white mark).
Old Feb 17, 2009 | 06:03 AM
TwoKSiR's Avatar
Right. But with the hondata already setting timing to 16 BTDC should I leave the gun at 0 then?
Old Feb 17, 2009 | 09:51 AM
Spunkster's Avatar
You are incorrect. The **** on the timing light must be set to the same value you enter in the set timing window. You then adjust the distributor to match.
Old Feb 17, 2009 | 10:04 AM
EJ1B18c's Avatar
I might be wrong but
That would apply if you were taking your readings from the TDC mark on the crank pulley.
If you were taking your readings from the 16Deg BTDC mark you would set your timing light to 0.
Old Feb 17, 2009 | 10:52 AM
93turbo16's Avatar
Exactly. You can do it two different ways with an adjustable advance timing light.
Old Feb 17, 2009 | 11:03 AM
TwoKSiR's Avatar
Ok. Well I did it off the 0 mark with the timing light set to 16.
efdxjdm
Oct 1, 2009 08:27 AM
a1320honda
Sep 17, 2007 02:58 PM
littlegreenb18
Nov 12, 2005 06:54 PM
handa
Oct 24, 2004 08:27 AM
rioninja
Aug 4, 2001 05:48 AM
