civic flood and miss at low rpm
ok here?s the problem i have my civic hatch when you start it idles ok for MIN THEN IT GOES TO idling up and down and missing and flooding when you pull out it misses and hops and skips till bout 3000 rpm then clears up ive changed plugs fuel filter ..i dunno whats wrong with it need ideas!
Re: civic flood and miss at low rpm
Revving idle (bouncing from normal idle to higher RPM) is usually a vacuum leak/ idle set incorrectly. Dying idle (bouncing from at or close to normal idle downward to almost stalling) can come from almost anything else. Bogging when you floor it from a stop is usually weak ignition. Hope this helps find the problem.
it goes from normal to almost stalling it doesnt bog it cuts in and out bad till 3000 doesnt matter partial throttle or full it does it some days others it dont
If it doesn't bog when you floor it from a stop then the ignition probably isn't the main problem. The most likely causes are compression & timing. Timing's easier to check but the comp sounds more likely.
ITLNstallion818
06-18-2005 02:56 PM
