possible crome iacv issue?
ive had this problem on 2 cars now.
symptoms:
cold start idle surge (1200rpm-1500rpm)
cel 14 (iacv)
feels like tps has dead spot from 0%-20% (sucks for cruising cause the throttle acts like an on/off switch)
once the engine comes up to operating temp the idle is perfect and it doesnt trigger the cel right away. it also wont act like there is a dead spot as often.
but once the cel comes on, the dead throttle spot is constant.
the cel will clear instantly if i cycle the key.
i looked around for this problem and didnt come up with anything..
in crome the idle controls are at 900rpm and 8% iacv compensation..nothing crazy i thought..
thanks,
jack
symptoms:
cel 14 (iacv)
thanks,
jack
Try cleaning the IACV with brake or carb cleaner. You could also test if the IACV is causing the TPS dead spot by disabling it in a P30/P72 or Gold map.
mikeunreal2
14
Feb 9, 2006 01:51 PM
