P28 w/ a burned circuit board. What's burned?
Old 12-14-2008, 07:12 PM
hostile1's Avatar
Default P28 w/ a burned circuit board. What's burned?
I picked up this P28 ecu earlier today and forgot to open and inspect it before handing over the cash. I got home and popped it open to find some part scorched along with the circuit on the opposite side. I plugged it in and my h22a started right up. It seemed to rev smooth, and drove around the block with no problems and no check lights. I haven't attempted to get it into vtec or redline because I don't trust a stock p28 to run it.
Any ecu experts have an idea of what the circled areas are, if they will cause any problems, and if I should keep the ecu and socket it, or junk it and buy another?
Thanks!
I apologize for the pics, but my camera isn't great and the pics get blurrier as I get closer.
Old 12-14-2008, 07:52 PM
mtber's Avatar
Looks like q31
It is burnt because some one swapped the two wire plugs for evap purge solenoid & probably intake air temperature.
Replace the iat sensor & remove the q31 transistor.
The ecu will still probably function normal.
Old 12-14-2008, 09:09 PM
hostile1's Avatar
It does have Q31 written vertically next to it and R135 below it.
Would I need to replace the q31 transistor, or remove it altogether? Do you think running the ecu like this would damage any sensors on the engine, or is it more likely to just run like crap?
Thanks
Old 12-15-2008, 05:03 AM
mtber's Avatar
Thanks
Just remove it, you won't need it.
The ecu should work fine.
Old 12-17-2008, 06:55 AM
hostile1's Avatar
Thanks again mtber! Had it socketed, chipped, and tuned yesterday afternoon and my H22a runs great! And with no CEL's!
Old 12-17-2008, 08:14 AM
full Circling's Avatar
Location: That's the wrong tone... I'm Skunk2 certified.
Ecu aidz
Charlie Moua
09-28-2017 07:30 PM
eka11day
Engine Management and Tuning
04-12-2011 10:32 AM
obuhmyuh
29
02-15-2008 01:00 PM
pootsiracer
10-19-2004 10:09 PM
HOND PWR
07-22-2003 05:44 AM
Quick Reply: P28 w/ a burned circuit board. What's burned?
