Tap the Map?
Old Jun 20, 2004 | 08:42 AM
Sketch_hs's Avatar
Default Tap the Map?
Hey I need to tap into my map sensor voltage output for "external" datalogging
what's the best/easiest place to tap into?
and what is the output range?
Thanks! I can't wait to start datalogging.
Old Jun 20, 2004 | 12:57 PM
Sketch_hs's Avatar
ne1?
Old Jun 20, 2004 | 02:11 PM
z6's Avatar
z6
what are you using for your datalogging?
Old Jun 20, 2004 | 03:41 PM
Sketch_hs's Avatar
Default Re: (z6)
laptop, connected to a wbo2, rpm signal and map sensor output. (load)
the wb software puts it all together, but i need to know where to tap the map signal off of, and if it's 0-5v, 0-1v or whatever....
Old Jun 21, 2004 | 12:24 AM
turbopimp's Avatar
Default Re: (Sketch_hs)
Tap the MAP sensor at the ECU pin. It is a 0-5 volt sensor, although the output signal never really hits 5 volts.
Old Jun 21, 2004 | 12:29 PM
Sketch_hs's Avatar
Default Re: (turbopimp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbopimp &raquo;</TD></TR><TR><TD CLASS="quote">Tap the MAP sensor at the ECU pin. It is a 0-5 volt sensor, although the output signal never really hits 5 volts.</TD></TR></TABLE>
thanks, do you know what pin it is?
Old Jun 21, 2004 | 06:04 PM
turbopimp's Avatar
What kind of car do you have? What year?
Old Jun 21, 2004 | 06:20 PM
Sketch_hs's Avatar
93 civic
b16a2
chipped p28
Old Jun 22, 2004 | 02:42 AM
turbopimp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sketch_hs &raquo;</TD></TR><TR><TD CLASS="quote">93 civic
b16a2
chipped p28 </TD></TR></TABLE>
Check pages 23 and 24 here:
http://www.apexi-usa.com/produ...e.pdf
The wire you want to tap is labelled "pressure signal" in diagram H2-a.
Old Jun 22, 2004 | 08:12 AM
Sketch_hs's Avatar
sweet
thanks H-T
MatthewMenze
Engine Management and Tuning
May 1, 2014 01:24 PM
kpowerdhatch
Oct 20, 2007 02:43 PM
aldong
Oct 8, 2006 06:15 PM
Dr Pooface
Nov 19, 2005 12:37 PM
