Help with base tune on 450cc injectors??
Old Mar 26, 2011 | 04:35 PM
Jimmy's Avatar
Global Moderator
Icon4 Help with base tune on 450cc injectors??
We just turbo'd my buddies hatch.. he's running a jdm d15b with a t3/t04e he's running a walbro pump and DSM 450cc injectors with 10 watt 10 ohm resistors.
I've got crome and flash & burn with the moates chip burner..
Wondering if someone could set me up a map with the fuel tables adjusted so we can drive this car to the dyno?
ANY help is appreciated
My email is Jimmy@Honda-tech.com
Old Mar 26, 2011 | 04:50 PM
Spawne32's Avatar
Default Re: Help with base tune on 450cc injectors??
http://www.xenocron.com/bins/
Old Mar 27, 2011 | 03:17 AM
CEPerformance's Avatar
Originally Posted by Spawne32
x2 just to get to the dyno though.
You can also used the fuel multiplier then just keep it out of boost.
Old Mar 28, 2011 | 12:55 PM
Jimmy's Avatar
Global Moderator
Got it. Thanks guys, I found one on there and burned it.. car seems to be running fine.. (good enough to drive to get tuned, anyway)
Old Mar 29, 2011 | 10:56 AM
Using someone else's map is hit or miss.
I've seen cars run forever on them.
I've also seen them last 5 minutes ha ha.
good luck with the tune
civickiller
Jan 24, 2011 04:37 AM
Poop111444
Aug 4, 2004 05:23 PM
B20fun
Oct 30, 2003 10:54 PM
Overblown-Teg
Jul 4, 2003 10:41 AM
cjmech
Jul 19, 2002 07:07 PM
