Ignition problem after AEM EMS install
Old Jan 10, 2010 | 09:14 AM
  #51
h22 civic's Avatar
Default Re: Ignition problem after AEM EMS install
ever get it rite?
Old Jan 11, 2010 | 05:41 AM
  #52
turbodcxbro's Avatar
Skunk2 Pro1's are not "Race cams" my friend... They actually aren't too much wilder than stock Type R cams...
Did you ever get things sorted out? I'm fighting idle issues on my B18C with Buddy Club stage II's in it as well. But I'm using Hondata on a chipped P28.
Old Jan 11, 2010 | 06:36 AM
  #53
92TypeR's Avatar
FSAE
You are confusing Pro1's with Tuner1's. The only other off-the-shelf camshafts I've seen with more aggressive low-cam lobes are the Pro2's and Pro3's. The primaries on Pro1's have more lift than the VTEC lobes on ITR cams... Far from being similar.
OP - On Pro2's and Pro3's, idle is usually around 17-19" on B-series motors vs 22-24" with stock or mild primaries. You will need to scale your MAP vs RPM table according to your new idle load.
sshh
Engine Management and Tuning
Feb 11, 2011 09:49 AM
Boostage
Jun 12, 2006 08:18 PM
yellowturbo
Feb 2, 2006 06:19 PM
sportridermike
Honda S2000
May 26, 2005 02:56 PM
E Swift
Feb 11, 2004 05:33 PM
