wideband o2
Old Mar 26, 2006 | 07:32 PM
sanfriz's Avatar
Default wideband o2
i have full dataloggin capabilities with my ecu using uberdata and ecu control can i just wire in the wideband and use the readings from my ecu or do i need to get a wideband lcd screen as well?
any help would be great
Old Mar 26, 2006 | 11:06 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: wideband o2 (sanfriz)
you can just wire it in. your wbo2 should have a narrowband wire and a wideband wire. you can use the narrowband wire to your ecu, and datalog that. ecucontrol also has support for different logging factors, such as o2 voltage, which when used with a conversion factor can give you the correct a/f ratio. if you have an innovate or plx logger i think the voltage feature is supported. either way the wideband logger translating to narrowband for your ecu should be much more accurate than the stock narrowband.
89dohcEF
20
Dec 7, 2003 02:07 AM
FMIDRC Racer
Aug 17, 2003 08:39 AM
civic_dreams95
Mar 11, 2003 11:08 PM
